Fatboy front wheel wobble
Old Feb 18, 2009 | 06:23 AM
abrailman's Avatar
abrailman
Default Fatboy front wheel wobble
My wifes fatboy has a bad wheel wobble when you take your hands off the bars.
With hands on you don't feel a thing. My Delux rides precfect with hands off at any speed.
Any suggestions, and don't say "keep your hands on the wheel".
Old Feb 18, 2009 | 06:38 AM
coop57's Avatar
coop57
I had the same problem last year I did the fall away adjustment, made sure cables etc were not in a bind - nothing helped. - changed the front tire and bingo no more wobble!
Old Feb 18, 2009 | 07:07 AM
bikermike2's Avatar
bikermike2
maybe unbalanced tire .or lost a weight some of them are just put on with sticky tape.
Old Feb 18, 2009 | 07:13 AM
kkinderen's Avatar
kkinderen
Happens to me often enough. For some reason I go through more weights than tires. I usually live with it until it is time to change the tire again. Not sure that's a good suggestion though.
Old Feb 18, 2009 | 07:52 AM
Bluzmn59's Avatar
Bluzmn59
Probably tire-related, either worn or out of balance. That is where I would start, anyway.
Old Feb 18, 2009 | 08:30 AM
LS1 WS6's Avatar
LS1 WS6
I had this problem last year, I removed my wheel and recentered it the correct way when I put it back on. I did not do anything to the wheel or tire and it still solved the problem.
Old Feb 18, 2009 | 09:15 AM
anubisss's Avatar
anubisss
Also tire pressure may be an issue. Just a thought.
Old Feb 18, 2009 | 10:04 AM
aviator's Avatar
aviator
IMO: I think I'd take it to a mechanic.... knowing my wife rides it. wouldn't want to take any chances.
Old Feb 18, 2009 | 10:42 AM
dennyo's Avatar
dennyo
Originally Posted by anubisss
also tire pressure may be an issue. Just a thought.
________yep______
Old Feb 18, 2009 | 04:16 PM
hdrider.tx's Avatar
hdrider.tx
Same thing happened to me on my Fatboy. Had the streeing head bearings adjusted. Pulled the weights off the front wheel and put dyna beads in the tire. At the right angle in the right light I can just see cupping on the tire. Adjusting the bearings and putting weights inside the tire got rid of the majority of the wobble. Once the tire is warmed up real good it's almost completely gone. Almost. I think once I replace the tire it will go away.
