throttle wont return need help
Old Mar 6, 2009 | 07:11 PM
huey408's Avatar
huey408
Default throttle wont return need help
bye the pics can u tell if these cables are in correct location i have installed them as they appear in the pic and have switched them around but bith ways the throttle will open but does not return
Attached Thumbnails throttle wont return need help-1111.jpg   throttle wont return need help-11112.jpg   throttle wont return need help-11113.jpg
Old Mar 6, 2009 | 07:50 PM
rbabos's Avatar
rbabos
Throttle body is spring loaded to return to idle. Note the connection needed to pull it open with your fingers. Twist the throttle and see which one pulls with the correct rotation of the grip. Match this cable to the correct tb connection and it will be correct. Now you can tweek as needed at the grip adjusting sleeves . Instead of telling you which one goes where, I wanted you to see how it all works. Without knowing how these two cables work as a unit in relation to the tb, you will never do a good job of adjustment. Make sure your thumb screw is loose before adjusting. Loosen both barrels at the grip quite a bit to allow tb to close. Tighten the adjuster that's closest to the front of the bike until slack is taken up. You will have slight play in the grip and on each release you will hear the tb make a click sound as it hits the idle stop. Now take up the slack in the other adjuster until the audible click on the tb is almost gone. Go back the other way until click is solid again. Check full throttle operation by looking at the stop on the tb arm hitting the casting. Once you have minimal play in the start of the grip rotation, an audible idle click and full throttle indication, it is adjusted. It takes a bit of fiddling at first to figure out all the adjustments and the effect of one against the other, but it will make sense eventually. Don't tighten the return cable too much or it will screw with the other cables adjustment. Just take up the slack.
Ron
Old Mar 7, 2009 | 07:05 PM
tk353's Avatar
tk353
run down to the dealer and take pictures of a bike like yours. then go home and compare, maybe also search u-tube
Old Mar 8, 2009 | 05:47 AM
swordy's Avatar
swordy
Big Kahuna HDF Member
hav you got the cruise control thingy on?? jus a thought its early over here. i had a mate whos byk wouldent start he had the kill switch on! = skunk n byks dont mix
Old Mar 8, 2009 | 07:24 AM
rjmac53's Avatar
rjmac53
let us know what happens...
Old Mar 9, 2009 | 06:47 PM
huey408's Avatar
huey408
i messed around with it yesterday i had the cables wright i adjusted the cables removed the slack but still have same problem i can open throttle then it stays there it wont return unless i turn grip by hand i put new bars,grips and cables on and am wondering if there is a clearance issue with the grips
Old Mar 9, 2009 | 07:39 PM
Dustmaker's Avatar
Dustmaker
When I just put all of mine together, I had the same problem. As already stated, make sure you get the right cable in the right hole on the throttle body. Then the next step is to loosen the control housing a bit. Then check to make sure that there is nothing binding the sleeve in the housing. Not much here to go wrong. Let us know what you find.
Good Luck! You will get it fixed.
Old Mar 9, 2009 | 10:55 PM
tk353's Avatar
tk353
i just remember i had that issue after changing grips. the plastic part that is where the thumb screw goes in to snug the grip fell out of the groove and caused the return to not work
Old Mar 10, 2009 | 02:00 AM
fairplay's Avatar
fairplay
check the grips again. loosten the torx screws a tad pill the throttle grip out a smidge and tighten. also, look for any kinks or tight turns in the throttle cable or return. just to state the obvious, did you loosten the thumb screw at the bottom of the throttle?
Old Mar 10, 2009 | 02:26 AM
huey408's Avatar
huey408
i dont think i ever touched the thumb screw but who knows it could be that simple ill have to take a look at that next
