It's here...
Old Mar 7, 2009 | 10:29 AM
  #31
128auto's Avatar
128auto
Does PCV work on 06 model? I am just curious.
Old Mar 7, 2009 | 10:30 AM
  #32
ranger56528's Avatar
ranger56528
Get it done...just start and before ya know it you will be done and riding....Dont forget to clean the pipes off REAL good.....I used acidtone on mine being how I had it laying around...
Did I say...Make sure ya clean the pipes off real good.Hahahaha.
Old Mar 7, 2009 | 10:33 AM
  #33
ranger56528
I know he(jamie) got it to work on 08 bikes.think PCIII would be 08/07 later.
Old Mar 7, 2009 | 10:39 AM
  #34
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
Asked Jamie (@fuelmoto) about PCIII vs PC-V and told him what I was doing to my 06 Fatboy and asked
what he reccommended and he said PC-V. So I can only assume that it's compatible and will work.
Old Mar 7, 2009 | 10:44 AM
  #35
ranger56528
WoW if he got it to work on 06 you know what Iam going to do....I will call him nxt week..
Old Mar 7, 2009 | 10:55 AM
  #36
P'colaHarley-17RGS
Well like I said I told him what I was doing, what I was working on, and what
I wanted so if it doesn't work it's on him. I'm 100% sure it will though. As matter
of fact it came in box labelled 00-06 Softail retrofit (or something like that... don't
have box here in front of me, I'm at work.)
Let me know if you find out different. thanks
Old Mar 7, 2009 | 11:05 AM
  #37
ranger56528
They must of if it says 00-06 retrofit.......good deal.
Old Mar 7, 2009 | 01:47 PM
  #38
Xuallus's Avatar
Xuallus
good advice so far, I'll add a little
make sure you clean your pipes very well before you start it up (sick of hearing that yet? )
the snap ring pliers are nice, but I managed with my bare hands to remove and reinstall them, needlenose will definitely work.
definitely get a torque wrench if you're doing your own mods, I can see HD voiding a lot of warranty if things aren't torqued to spec.
take your time, follow the directions, and have fun.
Old Mar 7, 2009 | 01:49 PM
  #39
P'colaHarley-17RGS
thanks man... that's good stuff (all of ya).
Old Mar 7, 2009 | 06:30 PM
  #40
tk353's Avatar
tk353
rubber gloves to help with grip and to keep oil from skin off the pipes. the old exhaust gaskets are suposed to be ok to reuse but i replaced mine. just remove with neddle nose or forcepts. i used loctite blue on the exhaust bolts and you are to only snug them using a 1/4 drive rachet and equal thread should be exposed. mine are about 3 to 4 thread. install them after lunch so you move slower. Place a towel under the pipes and between them utill they are finished.
the PCV will work 06 and the retrofit will allow you to use the 02 upgrade for full auto tune and save the dyno tune money.
