Fork oil Help
Old Mar 7, 2009 | 09:34 AM
ratt196635's Avatar
ratt196635
Question Fork oil Help
ok i have some softail forksliders off a 2000 FL model on my dyna and i was wondering if anyone here knew how much fork oil to put in them they are taller sliders than the wide glides i had on there. Also what weight oil should i use ? Here is a pic of the sliders I put on there yesterday.
Old Mar 7, 2009 | 10:22 AM
hardhead's Avatar
hardhead
mine hold 12 1/2 oz. if memory serves correct. Better wait on more opinions. I used Screamin eagle oil and it handles a little better now. it made my front end stiffer and less sloppy
Old Mar 7, 2009 | 10:23 AM
hardhead's Avatar
hardhead
thats 12.5 oz for each fork
Old Mar 7, 2009 | 07:13 PM
mgmmgm's Avatar
mgmmgm
Arrow SE Fork Oil
Hi,
Is SE fork oil thicker than standard HD fork oil?
Old Mar 7, 2009 | 07:36 PM
hpfatboy's Avatar
hpfatboy
Most of the guys change out the stock fork oil as it tends to let the front end bounce to much, not enough dampening. To stiffen things up a little i used the SE heavy fork oil, NOT the racing. The racing oil would be OVERKILL. As far as how much oil to add since your tubes are over stock length, that im not sure about. Best to stop in at a trusted Harley shop and ask this question. GOOD LUCK
Old Mar 7, 2009 | 07:38 PM
refuzeandrezizt's Avatar
refuzeandrezizt
Originally Posted by mgmmgm
Hi,
I believe it goes like this:
Standard = 10 weight
Screamin' Eagle = 15 weight
Screamin' Eagle Racing = 20 weight
Old Mar 7, 2009 | 08:23 PM
snip0721's Avatar
snip0721
Default fork oil
per 2000 manual....FL= 12.9 oz/382cc FX= 12.0 oz/356cc use the heavy duty, NOT racing.
Old Mar 8, 2009 | 12:57 AM
ratt196635's Avatar
ratt196635
thanks thats the info i needed now to get oil in them and get to riding again.
seanrsevern
Shovelhead
Jul 5, 2017 10:08 PM
warbisjohn
Apr 24, 2011 08:35 PM
OneBlackFly
Jun 30, 2006 09:13 AM
Patch
Mar 3, 2006 09:30 PM
HDF Tech
Aug 24, 2005 11:58 AM
