Chrome frame inserts
Old Apr 27, 2006 | 03:06 AM
speedracer's Avatar
speedracer
Default Chrome frame inserts
I recently purchased a set of chrome inserts that fit in the frame and are attached with double sided tape. One problem both of them fell off on the same side of the exhaust. I cleaned the area with alcohol befor installing them but was wondering if the heat from the exhaust was to much for them. Has anyone had the same problem and was wondering if anyone has any idea to make them stay on other than double sided tape. thanks
Old Apr 27, 2006 | 04:04 AM
ExBailBonds's Avatar
ExBailBonds
Default RE: Chrome frame inserts
(same here) Lost mine on the road within two days of installing them. It appears the tape can't handle the heat.
Old Apr 27, 2006 | 04:51 AM
SoftailBrian's Avatar
SoftailBrian
What was the weather/Temps like when you installed them? When I bought mine, the parts guy told me to do it in the WARM HEATED garage. He said it would help the tape stick better. I haven't put mine on yet so I'm not sure yet.
Old Apr 27, 2006 | 08:33 AM
Sanford's Avatar
Sanford
Mine too. It must be the heat.
Sanford
Old Apr 27, 2006 | 08:43 AM
FBFletch's Avatar
FBFletch
One of the inserts as off my bike when I bought it. It's my understanding that the fit of one of the inserts is typically pretty tight and that it needs to be trimmed slightly to keep it from popping out. Of course that's just what I was told by one of the guys at my local Harley dealership. I can't confirm that from personal experience.
Personally, I decided to go with the frame cover instead of the insert in light of the problems with the inserts. Of course, depending on your exhaust setup (i.e. in particular stock Fatboy exhaust), frame covers aren't an option.
Old Apr 27, 2006 | 10:37 AM
cmbucky's Avatar
cmbucky
I think Skip will know the answer.
He just loves chrome goodies.
Old Apr 27, 2006 | 02:49 PM
speedracer's Avatar
speedracer
The weather was fine when I installed them and I never even rode the bike for a few days after the installation. I did purchase another set of them today from the local HD dealer and they suggested super glue. I'm gonna wait a few days and give it a try unless any better ideas come along. Thanks
Old Apr 27, 2006 | 02:58 PM
dert's Avatar
dert
Use Goop automotive ...
Old Apr 27, 2006 | 05:03 PM
fxstcguy98's Avatar
fxstcguy98
mine have been on there for 3 years now, I lost the upper one on the exhaust side once. Use and expoxy type glue, they wont come off then. Just wiping with alchohol probably didn't clean it good enough.
Old Apr 27, 2006 | 05:37 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Did you make sure the piece was formed to the space? Did you remove or shave off the plastic heads of the button inserts?
