Rocker Danny Gray seat problem
Old Mar 31, 2009 | 12:16 PM
kylant's Avatar
kylant
Default Rocker Danny Gray seat problem
guys,
i just got my Danny Gray seat for my rocker and I cannot get the thing to mount. it is so tight that i can't get the brackets to line up with the bolt holes. i have tried everything. i loosened up the brackets and it still won't work. any tips, advice, suggestions?
also, did you guys keep the plastic battery cover in place? or did you have to remove it? I have tried both ways without success.
thanks
Old Mar 31, 2009 | 12:30 PM
57RebelRocker's Avatar
57RebelRocker
Sorry I can't help...got mine back from them and it fit good...although mine was the heartland seat and it just slips on in front and lays on the fender...try calling danny gray
Old Mar 31, 2009 | 12:48 PM
jasonhua's Avatar
jasonhua
I had the same problem, but I bought mine from Denniskirk website. I just return it last friday, mostly becuase I didn't like the way it felt when I sat on it. It looks good though.
Old Mar 31, 2009 | 12:59 PM
variablek's Avatar
variablek
Basically you can leave or remove the trays...I took mine off because the seat was putting a little pressure on it.
As for fitting it...you might need to bend the metal tab at the end up or down...Mine was really loose when I got it so I had to bend the tab up to fit under the gas tank better...for you, you might need to bend it down a tad...
Hope that helps.
Old Mar 31, 2009 | 02:21 PM
DragonSlayer08's Avatar
DragonSlayer08
Originally Posted by kylant
guys,
thanks
When my son and I put mine on we could not get it to line up at first. One of us had to push the seat forward from behind and the other put in the bolts. It has been easy to take on and off ever since.
I left the battery cover in place, protects the seat bottom and battery.
Old Apr 1, 2009 | 07:18 AM
tk353's Avatar
tk353
call danny gray as i hear they are very helpful
Old Apr 1, 2009 | 08:21 AM
variablek's Avatar
variablek
How did it turn out? Did you get it installed?
Old Apr 1, 2009 | 10:21 AM
kylant's Avatar
kylant
i called danny gray, they said they have never heard of this problem before, i was at work all day yesterday so did not have a chance to work with it. i will try a little today before work, but if i can't get it i have tomorrow so i will figure something out.
thanks for the help
Old Apr 1, 2009 | 10:30 AM
DaSham58's Avatar
DaSham58
When I first installed my DG it was a little stiff getting the mount holes to line up but now it comes off and back on with no problems.
Old Apr 1, 2009 | 10:52 AM
tk353's Avatar
tk353
glad i have a mustang
