Installing the rear wheel incorrectly
Old Apr 6, 2009 | 02:46 PM
anubisss's Avatar
anubisss
The only way the wheel would shift is if your nuts (pardon me) that align the axle were loose. Is everything tight? Could ahve jsut been installed a little off kilter.
Old Apr 6, 2009 | 02:53 PM
Dozer1's Avatar
Dozer1
Everything seems tight. I ran it up to around 70 over the weekend and didn't notice anything unusual. I assume I would get a vibration or something if there was a problem Again, just happened to notice it when I was cleaning it up after the ride.
Old Apr 6, 2009 | 02:59 PM
anubisss's Avatar
anubisss
Just to be certain you might want to check and make sure the spacers are on the correct sides and in the right place. Grab each spacer with your fingers and see if it moves back and forth at all. If your spacer moves it is in the wrong place. Don't ask how I know.
Old Apr 6, 2009 | 03:29 PM
Dozer1's Avatar
Dozer1
Everything feels tight. Thanks for the tips. Great looking bike you have by the way.
Old Apr 6, 2009 | 03:48 PM
128auto's Avatar
128auto
I had more than 5 people pointed at my fender in the past and said the wheel is off center, it sounds stupid but the rear fender is mounted slightly off center from the factory, it's a Harley!
Old Apr 6, 2009 | 04:48 PM
rsavage's Avatar
rsavage
Check how your drive belt is riding in the rear pulley. If the wheel is misaligned you will wear the edge. Should show a little space either side of the belt.
Old Apr 6, 2009 | 05:08 PM
spooner's Avatar
spooner
On my 07 Deluxe the wheel is the same way. On the left, the gap between the tire and the fender is smaller than the gap on the right side.
I went to the dealer and looked at the other Deluxes', they are all that way. No biggie. I just make sure that the centerline of the tire is correct and not cocked one way or the other.
Old Apr 6, 2009 | 06:28 PM
Dustmaker's Avatar
Dustmaker
The tire/wheel is offset from one side more than the other. You can see this very easily by placing your fingers in between the tire and fender on each side. As stated above, if your belt is running true, then your wheel is straight.
Old Apr 6, 2009 | 10:49 PM
Dorkman's Avatar
Dorkman
Normal. The stock wheel setup runs around a 1/4 inch to the left. If you futz with it you will need to move the brake caliper as well.
Old Apr 6, 2009 | 10:54 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
yep mine sits to the left also. straight from HD
