Alright well I thought I was slick because I haven't had a problem in my build so far. However, I installed a new ss front brake with all new banjo bolts and washers and I have no pressure at all.
Before you ask, I'm bleeding via the service manual and I've got good fluid flow coming out of the bleeder valve but the pressure just wont build.
Also, I took the cover off and watched the plunger move (it does) and bubbles do come up when i release the handle...
Theres ya problem right there Bloke...theres not ment to be any bubbles coming through....keep following the procedure untill all the bubbles are gone and only fluid coming out the nipple,,,using fresh fluid everytime ya top the master cylinder up...sometimes it takes along time to get all the air out...
yrs ago on one of my bikes with dual front bakes which is even harder to bleed out, I worked 2days to get the air out and a firm pull. never was like factory after that..but good enough to go with.
