Fall Away on FXSTC
Old Apr 20, 2009 | 06:26 PM
Figstr's Avatar
Figstr
Default Fall Away on FXSTC
Ok, had some front end work done and I've got one hell of a wobble. Brought it back to my indy and he tightned up the fork nut on top and the adjusting nut underneath. It didn't solve the problem so I decided to check the spokes as I had some loose spokes the last time this happend. Well, got the front end off the ground and I noticed no fall away. The manual says to loosen the fork pinch bolts, yet they aren't shown on the blow-up of the front end. So, what the heck are fork pinch bolts and does anyone have a pic? I'm thinking, as common sense would tell me, they're referring to the top nut and adjustment nut.
Old Apr 21, 2009 | 05:35 PM
WFA's Avatar
WFA
Do a search here on "fallaway" and you'll get tons of info.
Old Apr 21, 2009 | 06:01 PM
Dorkman's Avatar
Dorkman
Pinch bolt(s) are part of the triple tree and come in horizontally, the top one just below your adjuster nut. Not sure of your model, but likely an Allen key to loosen.
Old Apr 21, 2009 | 07:28 PM
jimmers1817's Avatar
jimmers1817
Here's a recent thread on the subject. On my Heritage the clutch and brake cables interfere too much and have to be disconnected in order to get an accurate "reading".
On my bike there are 3 pinch bolts. One at the steering head (allen) and two in front of the forks under the cover.
Good luck
https://www.hdforums.com/forum/softa...ring-head.html
___________________
2008 Heritage Classic: His
2008 Deluxe: Hers
Ridewva
Oct 4, 2016 12:47 AM
Alain
Aug 19, 2013 05:53 AM
GlobeWarmer
Aug 12, 2013 02:02 PM
crepe
Jun 25, 2010 05:43 PM
WARG
Feb 23, 2008 12:01 AM
