handlebars
Old Apr 30, 2009 | 01:16 PM
jm04's Avatar
jm04
Default handlebars
wanting to adjust handlebars,can i just unloosen the 4 bolts adjust,then tighten them back up,or do i have to take them out and put some locktight or something else on them?thanks in advance.
Old Apr 30, 2009 | 01:22 PM
jimmers1817's Avatar
jimmers1817
Just loosen the allens and torque them back to specs.
______________________
2008 Heritage Classic: His
2008 Deluxe: Hers
Old Apr 30, 2009 | 02:01 PM
jm04's Avatar
jm04
does anybody know what to torque those 4 allens to?cant find it in the owner's manual
Old Apr 30, 2009 | 02:50 PM
jimmers1817
12-15ft lbs.
Probably doesn't matter much but there is a certain recommended sequence. What model do you have.
________________________
2008 Deluxe: Hers
Old Apr 30, 2009 | 02:56 PM
jm04's Avatar
jm04
04 fxst
Old Apr 30, 2009 | 03:06 PM
jimmers1817
On all softails except the rockers you tighten the back screws first, then the front ones. Glad to help but I highly recommend you get yourself a service manual. Best money I've ever spent on my bike(s). They run from $50-$60.
___________________
2008 Deluxe: Hers
priceamp's Avatar
priceamp
You want to alternately tighten the bottom bolts first to the point where the surface of the risers clamp meets the risers, then alternately torque the top bolts to the specified torque value.
Old Apr 30, 2009 | 03:56 PM
GoateeInTheWind's Avatar
GoateeInTheWind
should those bolts get blue locktite like everything else?
Old Apr 30, 2009 | 04:00 PM
Whoad00d's Avatar
Whoad00d
plus pending on how extreme you adjust your handlebars you might want to adjust and twist your control levers as well so they feel right again like if you push your bars forward your controls will point up rather than at you and your brake and clutch will be pointing towards the ground.
Just something to think about.
scooter34
Jun 9, 2009 11:39 PM
jimmers1817
Apr 8, 2009 10:03 PM
onaroll123
Apr 4, 2009 09:32 PM
