Brake Bleeding
Old May 2, 2009 | 08:40 AM
tlb's Avatar
tlb
just make sure you do not get dot 4 brake fluid on your paint. the brake fluid can and will eat the paint on your tank or fender. this is something people do not consider on a car.
Old May 2, 2009 | 04:40 PM
tk353's Avatar
tk353
clean your pistons
http://www.lyndallracingbrakes.com/service_tech.htm
http://fatbillscustoms.com/
Old May 2, 2009 | 07:38 PM
deni's Avatar
deni
Do yourself a king size favor, cover your paint with plastic & then again with old towells to be on the safe side & don't over torque the MS cover screws. Then move the lever slowly in & out.
Regarding speed bleeder screws, I bought 'em & chicken'd out. They were sooo tight I thought I was gonna' foul the caliper threads.
best tool: wife @ the lever
Old May 2, 2009 | 08:57 PM
rubiconMike's Avatar
rubiconMike
Originally Posted by story808
The brake is gravity and is not just like a car... leave the bleeder screw shut "tight" and fill master "rags" are a good idea leave the cover off and pump the brake nice and slow and just be patient, nice and easy... you see little air bubbles coming up from the fluid... when there are no more air bubbles coming up cover the master with a rag and pump it harder you'll see the fluid hit the inside of the rag and you should feel some pressure... be patient it'll work... some times you have to leave it for a while and let the air work it's way up. I think every time you crack the bleeder screw it like starting all over... IMO Good luck
+1 Reverse Bleed it.
If the above doesn't work try this: http://www.moccsplace.com/images/bra...er/bleeder.htm
GibsonSG05
Jun 13, 2021 02:14 PM
JDavis187
May 28, 2014 11:59 AM
06Cummins
Jan 8, 2013 06:06 PM
sammer4u
Wheels/Tires
Jun 30, 2011 07:22 AM
osirisdean
Jun 16, 2010 06:36 AM
