Python Pipes and Backfire
Old May 15, 2009 | 03:13 PM
Rebel11's Avatar
Rebel11
2nd Gear
Default Python Pipes and Backfire
Hi folks, I have Pythons on my Heritage Softail and on De-Cell I get some backfire aand sometimes its loud. I HATE IT! What can I do to get rid of it? Also someone told me its not Dyno'ed right another said its unburned gas! Im so confused and I dont know. Im thinking of switching pipes altogether....WHAT DO I DO??????
Old May 15, 2009 | 03:23 PM
BigJoeNY's Avatar
BigJoeNY
Been answered many times already. Could be a few things. The search feature on this site is your best bet. A search here should help.
Electrical/Ignition/Tuner/ECM/Fuel Injection
https://www.hdforums.com/forum/elect...-injection-55/
Air/Fuel mixture not correct or leaking exhaust gaskets are common causes. All simple fixes... Good luck...
Old May 15, 2009 | 03:25 PM
Slowpoke84's Avatar
Slowpoke84
Are they Python slip-ons? Could be something as simple as an exhaust leak at one of the seems. If so, just use Copper Hi-Temp RTV Silicone to seal it up.
Old May 15, 2009 | 05:52 PM
Rebel11's Avatar
Rebel11
2nd Gear
The exhaust leak has been checked and its not that. There are no leaks at the gaskets. I was told that Python pipes are known for backfire. I find that hard to believe. They are the complete pipes set and were installed by the dealer. Im really lost with this. I will check the search engine in here and see what it might be.
Old May 15, 2009 | 06:33 PM
oct1949's Avatar
oct1949
If its a air leak U haffta get them sealed first, even the tuner cant get the decell pop out if thats the case.
If no leaks then he should get 95 % out.
Old May 15, 2009 | 10:47 PM
BigJoeNY's Avatar
BigJoeNY
How do you know it's not or how did you check for the leaking gasket? I don't know if it's fact but a few mechanics who claim to work at the Stealership posted online that they never change the exhaust gaskets when installing new pipes. All you need is a tiny tiny leak from improper fitment and POP POP POP on decell. Ask me how I know.....
Old May 15, 2009 | 11:27 PM
KumaRide's Avatar
KumaRide
Did you also change the AC? Do you have the dealer stage 1 download? Very common for pipes with stage 1 - pipes and AC - to pop on decel. Mine did it until I installed a cam. You can richen the fuel mixture with a PC or ... to get rid of it.
Old May 17, 2009 | 11:49 PM
Rebel11's Avatar
Rebel11
2nd Gear
As for the Leak I had it checked at the dealer..I also checked with "Cigar Smoke" at the connections and the gaskets. (If thats a test I have no idea) at this point I am trying everything before I switch pipes to Vance and Hines which was my first choice but listened to others about "Pythons" being so Gooood!!!!! Now Im pulling my hair out trying to fins out why. I will probably adjust the mixture and try that. I was hoping someone else had the same and the fix for this situation. Thanks Brothers... ride safe.
Old May 18, 2009 | 06:11 AM
MasterGun's Avatar
MasterGun
It's definently NOT the Pythons. (My Pythons are actually the same as Vance & Hines Big Shots. Just has the Drag Specialties brand name. My Bike Doctor said they are made by the same folks.) I have them on mine and love the sound. My suggestion is getting a Power Commander and make sure the correct map is loaded. I used M813-038 from the PC web site. It has a slightly rich fuel setting.
Old May 18, 2009 | 06:14 AM
Hammer107's Avatar
Hammer107
A pipe is a piece of metal...it cannot create a backfire regardless of the name brand.
You either have an exhaust leak or an improperly tuned bike...period.
If changing to V&H cures anything...it will only be because you probably cured the leak.
