shifting problem. Return spring??
Old May 16, 2009 | 02:03 PM
billymons's Avatar
billymons
Default shifting problem. Return spring??
Just bought my first HD 93 heritage softail with 34,000 miles. yea lots of miles but this thing ran great and looked great and the price was right. Im great with the tools and will be tearing into it myself. But. I never touched a harley before. Give me a chevy v8 and ill do it with my eyes closed. Any way i got my first problem. It shifts into first but has to be helped to shift into or down in other gears. heel toe method. Ive been reading about a return spring. sounds about right. but im going to start with cleaning and grease of shift linkage/rod. Any other tips? thanks, Bill
Old May 16, 2009 | 02:07 PM
billymons's Avatar
billymons
well my linkage and rods are clean as can be. operate real nice. looks like I need to adjust or check into the vertical rod that comes up from the trans??? any suggestions . I didnt get my fixit manual yet. I see a nut/screw next to the vertical rod, Is this an adjustment? this rod wiggels jeft and right. should there be spring tention each way? thanks, Bill
Old May 16, 2009 | 06:30 PM
57RebelRocker's Avatar
57RebelRocker
my bad posted in wrong forum sorry
Old May 16, 2009 | 06:54 PM
CamFX's Avatar
CamFX
The shaft that the shift arms pivots on needs greased. Remove your shifter (both heel and toe) clean the shaft and use a good marine grease on it. put it back together and it should fix it. Common problem on these bikes. Especially if you ride in the rain.
Old May 16, 2009 | 09:36 PM
crazybastid83's Avatar
crazybastid83
Take off the heel toe levers and grease up the spline.
kaykav
Oct 7, 2013 11:26 PM
Jucifer
Mar 10, 2012 12:21 AM
billymons
May 20, 2009 08:59 PM
KeithJK
May 13, 2009 07:11 PM
Figstr
Sep 3, 2008 05:59 AM
