shifter not returning
Old Sep 30, 2013 | 09:20 AM
kaykav's Avatar
kaykav
3rd Gear
Default shifter not returning
Annoying problem exists... Only when bike is running, the return spring action on the shifter does not do its job. I shift from neutral to 1st and the shifter arm does not return to its original position. The same happens from 2nd to 3rd,and so on. However this happens about
40% of the time. I just have to slightly nudge the shifter arm to its original position to set it up to shift to the next gear. Coincidentally I just finished adjusting the clutch (twice) by the shop manual. Clutching works fine. Its that annoying shift problem that needs attention.
Any ideas? Thanks
Old Sep 30, 2013 | 09:22 AM
deano360's Avatar
deano360
we ran into the nsame problem with our 2013 slim and it turns out that it just needed to be worked a little to break in, now it work fine
Old Sep 30, 2013 | 09:55 AM
QC's Avatar
QC
You don't say what year it is.
Make sure all moving parts in the linkage from to toe pad to the shift arm are clean and oiled. I have seen this in here before and it was just a matter of taking everything apart and cleaning it up.
If that doesn't fix the issue, the return spring in the trans may be broken.
Old Sep 30, 2013 | 10:32 AM
kaykav's Avatar
kaykav
3rd Gear
OK I w-d 40 as best I could . I'll take the bike for a run to try it out. Thanks..
By the way is it difficult to replace thre return spring ?
Old Sep 30, 2013 | 11:29 AM
QC's Avatar
QC
I have not done it, but I believe it will require removal of the trans. Hopefully someone who has done this will chip in. Time to invest in a factory repair manual.
Old Oct 6, 2013 | 07:46 AM
kaykav's Avatar
kaykav
3rd Gear
Smile shifter not returning
I took the shifter linkage apart, cleaned the rod with steel wool, put some grease on it,put back together: Works great. Thanks for your input....
Old Oct 6, 2013 | 08:44 AM
QC's Avatar
QC
Cool! Glad it was something easy!
Old Oct 6, 2013 | 10:18 AM
08Nighttrain's Avatar
08Nighttrain
good job now wash that thing once per year to keep grime from clogging parts!
Old Oct 7, 2013 | 05:14 AM
oct1949's Avatar
oct1949
KK,, its not just the grim that make the linkage stick. Its also some rust.
WD 40 is not the best to use to lube it, any good oil will do it, I have a small oil can I filled with the Syn oil that I use in the car. Then at every oil change I give the lingage a shot.
If U don't ride much, then oil the linkage every fall and spring to keep the linkage free moving.
I've even seen some members in here put a Grease Zerk in the frame where the linkage shaft goes through.
Old Oct 7, 2013 | 11:26 PM
brymer84's Avatar
brymer84
Had the same issue, clean and grease and you are good to go. It happened to me on the way back from Sturgis. It wasn't a fun ride home. (haha)
cwsharp
Aug 22, 2022 11:54 PM
nwpwr22
Ironhead
Apr 29, 2012 07:44 AM
Mr.Black
Jun 23, 2010 09:28 AM
pontiac80
Apr 6, 2009 07:07 PM
Figstr
Sep 3, 2008 05:59 AM
