Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Shifter problems
Old Jun 22, 2010 | 03:00 PM
Mr.Black's Avatar
Mr.Black
Stage II
Default Shifter problems
Hi, I'm new to the forums but I am in need of some tech guidance. I have a 2006 Softtail Nightrain with some shifter issues. When I shift or downshift my shifter doesn't spring back so that I can shift again. I can lift the lever up and shift again but it doesn't spring back, it feels like it is gummed up. Any ideas?
Old Jun 22, 2010 | 04:12 PM
fireman031967's Avatar
fireman031967
Default Shift problems
Take it off and clean and lube the shaft. I used never seize on mine and haven't had a problem since. You can search this subject as it has been gone over before if you need more instruction but it easy to do.
Old Jun 23, 2010 | 09:28 AM
sqdealgeorge's Avatar
sqdealgeorge
The shifter spring inside the tranny is probably broken Hopefully the broken spring didn't fall into gear
cwsharp
Aug 22, 2022 11:54 PM
kaykav
Oct 7, 2013 11:26 PM
128auto
May 7, 2013 09:32 PM
busch
Aug 15, 2009 06:20 PM
pontiac80
Apr 6, 2009 07:07 PM
