So, the infamous front stoplight switch probs..
Old May 23, 2009 | 07:58 PM
ronyd's Avatar
ronyd
Default So, the infamous front stoplight switch probs..
Well, my buddies have been telling me that my stop lights intermittently at times. So, looking at my circuit diagrams, and checking voltages everything seems to be fine. But, here's the problem. If I pull the front brake lever forward (toward front wheel), and then apply the rear brakes, stoplight works fine. So, is this an adjustment or a bad front stoplight switch? Is the switch supposed to be engaged (that is pushed in normally), then when brake lever is used, disengages the switch? little confused here...
Old May 23, 2009 | 08:50 PM
Lucky 13's Avatar
Lucky 13
Little confused on your wording but if you are asking how the handle bar switch works, when the lever is released it pushes the switch in and breaks the circuit.
Old May 23, 2009 | 08:54 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I think he is asking if his switch for the rear brake light is working properly. I can't answer that.
Old May 24, 2009 | 05:44 AM
ronyd's Avatar
ronyd
Sorry guys for the confusion. Yes, I'm was asking how the handlebar switch should work. So, Lucky13, you got it right for me. So, when the brake lever is NOT in use, the lever is holding the switch "in". So, is this an adjustment to the brake lever?
BTW, I did a handlebar install last year, so had everything disassembled. Never noticed this before. So I guess I'll disassemble the switch housing from brake lever bracket and re-install?
Seems a little weird that the brake lever is not pushing against the switch to hold it in when not in use....
Old May 24, 2009 | 06:40 AM
chester1957's Avatar
chester1957
Did you put a spacer between the brake lever and housing before working on the switch cover? The front brake light switch is easily damaged.
Old May 24, 2009 | 07:30 AM
crazybastid83's Avatar
crazybastid83
You need to solder in a new switch. Squeeze the brake lever and put a zip tie end in there. This prevents the lever from pinching the switch when you remove it. Look at the switch, usually if it is broken, it is noticeably distorted. I would guess it will be your switch.
If the brake lever is really sloppy, it would be a brake bleeding job, or a master cylinder rebuild.
Old May 24, 2009 | 09:13 AM
ronyd's Avatar
ronyd
I do in fact place a spacer between lever and switch whenever I work on the right hand control. But, sounds like there's a problem with the switch and somehow got damaged. I'll check it. Bike is still under warranty, but hate to tie the bike up if I can fix it myself. I'll go down to HD today and find out how muchb the switch is...
Old May 25, 2009 | 12:42 AM
FLSTC4ME's Avatar
FLSTC4ME
Changing my second one out now!POS
Old May 25, 2009 | 05:15 AM
ronyd's Avatar
ronyd
FLSTC4ME, what was your symptom?
Looking at my front brake lever again, it's definitely not returning back all the way against the switch. Just a 1/16th of an inch less is all i need and the switch would be activated. It's possible I guess that the switch is sticking and not allowing the brake lever to return properly. If I flick the brake lever, it has enough of force to return against the switch and all is well.
Old May 25, 2009 | 08:44 AM
eod_punk's Avatar
eod_punk
Sounds similar to what happened to me. I broke off the little nipple that sticks out from the boot the protects the switch. The switch was fine other then that though, I just found an old scrap piece of plastic and trimmed it down to the size of the little nipple and glued it back on to it. HD wants about $60 for a replacement switch, which I think is crazy. Look at one of your friends bike that has a properly working switch and then compare it to yours. Just squeeze the lever and use a flashlight to look at the switch, no need to disassemble the switch housing.
