FatBoy Rear Tire
Old Jun 5, 2009 | 08:06 PM
Soft06's Avatar
Soft06
Originally Posted by crazybastid83
poor tite pressure maintanance=poor mleage I usually get at least 10k
+1......the biggest reason for low tire milage.
Old Jun 6, 2009 | 01:18 AM
ChromeJunkie's Avatar
ChromeJunkie
+2 on keeping an eye on air pressure. I never got less than 12,500 on the OEM Dunflops. I am on my 3rd set of Avons and the worst I got was 10K on the rear tire. This is because I ran it with too little air. Try adding a lb or 2 over what the owners manual sez, you may be surprised.
Old Jun 6, 2009 | 11:59 AM
oct1949's Avatar
oct1949
Must be different compound, I would have though the wider tire would do better than the 150 on mine.
9,7k on org. and still had a little more, but last spring we get a lot of rain, so I went new.
18.8k on her now and still more left.
At 20k I'll get both replaced, so that's a little over 10k on 2nd rear.
Also that's 95% two up riding and Grandma and I total around 400#'s
Old Jun 6, 2009 | 12:49 PM
Rabbit_'s Avatar
Rabbit_
Is this a problem inherent to the Fatboy?
Is there a reason why Fatboy owners are getting such lousy mileage out their tires, I managed to get 24000kms which is just less than 15000 miles on my stock tires and the cords weren’t even showing yet. I like some of the others check my tire pressure regularly and run 40 pounds in the rear tire, maybe that helps, but generally I had no problems with the stock Dunlops.
Old Apr 30, 2010 | 08:53 AM
Danny D's Avatar
Danny D
There is a BIG difference in different size Harley tires. The 200M that comes on a 2007 and up Fatboy is totally different than 180's or other more narrow tires on other models. 200's are made with a softer compound and therefore wear quicker.
I average about 5,000 miles on a rear tire for my 2007 Fatboy with just over 28,000 miles so I have replaced a few. I use synthetic oil in my bike so it seems that every 5,000 miles I take it in for a oil change and a new rear tire. Sad but true.
Old Apr 30, 2010 | 09:23 AM
Skeezmachine's Avatar
Skeezmachine
Default Curious about this also.
I'm curious whether this is a Fatboy issue or tire type issue. I know that my Bones runs a 200 Dunlop but it is not the same as the Fatboy's stock tire (or at least it wasn't at the time I changed tires). The Bones runs a D401 200/55R/17. I got well over 12k on my first tire and the wear marks were not yet showing when I changed it out. I am approaching 20k mile on my bike and the current tire still looks pretty good. At the time, the Bones was the only model Harley that ran that specif Dunlop tire. Maybe one of these on your Fatboy might get you farther?
Old Apr 30, 2010 | 02:04 PM
WoodsHog's Avatar
WoodsHog
I got 3200 on mine and it don't look like it'll make it past 7000.About 1/2 gone.I run 40 psi in it.I thought maybe I ought to try 38 in it.The center is were its gettin thin.
Old Apr 30, 2010 | 02:39 PM
FrozenInTime's Avatar
FrozenInTime
Just changed mine. 5250 miles, tire shot. I ran a little higher psi because of my ... weight.
Old Apr 30, 2010 | 03:14 PM
07Fatty's Avatar
07Fatty
3rd rear 15000 mi but i do ride aggesive so im told
Old Apr 30, 2010 | 03:22 PM
07Fatty's Avatar
07Fatty
ok I checked pressure it was 28 duh I better get more on top of my checking Im going to try the 40 psi for the ride tommorow
