back from dyno
Old Jun 9, 2009 | 03:05 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
+1 on the street *****!
I'll be replacing the heads on mine over the winter.
your #'s look good for pipes ,A/C and tuner.
__________________
09'FXSTB 103"ci PRO Stage III kit, heavy breather,Black Hookers
104.10TQ / 97.75 HP
What have you done so far on that 103" street Ho' to get those numbers and what heads are you thinking about?
Old Jun 9, 2009 | 06:35 PM
Mark g's Avatar
Mark g
It was a Pro SE kit. Cylinders,Pistons,SE pro tuner,Cams and high lift valve springs. I then added the heavy breather and black hookers.
I'll most likely go with a set of hi flow SE heads.A bigger throtle body and bigger injectors.Tmax also on the list.
I'm going for street ***** on Crystal!
The SE race catolog got lots of goodies!
Old Jun 9, 2009 | 07:37 PM
Sash302's Avatar
Sash302
Originally Posted by oct1949
there is a thread on page 1 in this softail section for posting dyno sheet, Its called "DNYOS for SOFTAILS
Its a sticky thread at the very top, why not put yours in there...
Just wandering cause I cant see on your sheet was your run a SAE or STD dyno run??? It will say on the sheet somewhere..
SAE.
I already post this there?
what is the differences between sae and std?
Old Jun 9, 2009 | 09:49 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
For the money... You may consider sending your stock heads to one of the more reputable porting shops. Big boyz, Hillside etc..etc..
IMO A set of well worked stock heads from one of the reputable indy build shops can absolutely work better than a set of "Catalog" heads and cost you less to boot!
A good motor guy can do incredible wonders with what you already have. Save yer' dough for more cold beer and chicks and contact a solid Indy shop with a rep for building fearsome motors.
Just wanted to throw out an alternative as bang for the buck is crucial in todays tough economic times.....
These guys build some straight up street ****** that are ferocious.http://www.hillsidecycle.com/
Old Jun 9, 2009 | 10:06 PM
silvrbill's Avatar
silvrbill
Originally Posted by Sash302
SAE.
Some info on that here...
http://wahiduddin.net/calc/cf.htm
Old Jun 10, 2009 | 05:28 AM
hpfatboy's Avatar
hpfatboy
Mr. Wizard
Aug 31, 2016 08:19 AM
HDCrossbones09
Jan 5, 2012 05:22 PM
azpsychobilly
Jul 22, 2010 08:24 AM
smokewagon
Jan 21, 2010 01:49 AM
AceHog
Oct 10, 2006 08:19 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
