Ok, I know several of you have relocated or removed the front turn signals. I was curious the steps to do so. I know it may be a dumb question, but I really dont want to start pulling on wires I shouldnt be (was just going to yank the wire out of the actual turn signal). Installing a tank lift and the lights will hit so need to get them out of the way. Thanks for the help.
The first option requires re-routing wires the second option is easier and takes less time. I did the second option and have a 2˝” tank lift and it will work with a 3" lift.
I'm running the Front Turn Signal Relocation Kit on mine. It was fairly easy to do and I like the look of it better than the signals on the bars. Just take your time and follow the instructions.
Yeah, I've seen the different options for what to do with the signals. However, I'm more so asking how to actually disconnect them. Just afraid to think I can just pull something out and end up ripping wires out I'm not supposed to by yanking of them.
Got to unplug them. The connection is on the right side under the fuel tank and use a paper clip, jewelers screwdriver, or safety pin to remove the wires from the connector. Its a lot more complicated than pulling the wire especially if you want to reuse OEM connectors. I personally have the Harley LED turn sigs in the mirrors. Very clean look
