rear sprocket??
Old Jun 14, 2009 | 12:36 PM
NTrain177's Avatar
NTrain177
Default rear sprocket??
Does anyone know the tooth count on a rear belt sprocket of a 2008 softail? I kept counting 66 but that seems odd, I thought they were 65 tooth...must have miss counted? Has anyone tryed going from a 65 tooth to a 70 tooth sprocket for extra bottom end power?
Old Jun 14, 2009 | 12:55 PM
Carmell RKC's Avatar
Carmell RKC
66 should be right, thats what my 09 is. I dont have any personal experience with switching pulleys.
Old Jun 14, 2009 | 02:28 PM
NTrain177's Avatar
NTrain177
yeah i looked around and 66 is what it came on it
Old Jun 14, 2009 | 03:47 PM
Shag67's Avatar
Shag67
I had a similar thought about my Dyna... just started looking today. You might find this link interesting:
http://www.andrewsproducts.com/PDF_f...eltPulleys.pdf
Old Jun 14, 2009 | 10:49 PM
oct1949's Avatar
oct1949
maybe your manual would tell ya!!! mine does
Doing a search in this forum and even Google will get most of your questions answered also .
Old Jun 15, 2009 | 05:19 AM
Oldpanrider's Avatar
Oldpanrider
'07-'08 are 66 tooth. '09 are 68.
Old Jun 15, 2009 | 07:29 AM
tk353's Avatar
tk353
mine has 66 and i was thinking of going to 70 but the width is wrong. cheaper to go to lower tire profile.
you can find the sprocket size here
http://www.totalmotorcycle.com/photo...tailDeluxe.htm
Old Jun 15, 2009 | 06:12 PM
NTrain177's Avatar
NTrain177
im sure someone in the great wide world of after makret parts makes a 70t that is the width of a 66? or i wonder if the new 68 off the 09 would be the same width? I have also been kicking the idea of the Evloution industries 30t primary sprocket kit...seems like that kit would do what i want
Old Jun 15, 2009 | 07:36 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
If you want more low end from a pulley swap, swap out the one inside of the primary where the front of the belt attaches too. this is a pretty common swap. Or you could swap the gearing on the primary chain for the same effect.
Old Jun 15, 2009 | 07:46 PM
tk353's Avatar
tk353
i have heard that swapping the primary gear is a major job. also i have not seen the 68 tooth sprocket. what model would that be from? i also understand they use 70 tooth in europe.
