wires thru bars
Old Jun 14, 2009 | 06:58 PM
RHillbilly's Avatar
RHillbilly
Default wires thru bars
anybody have any suggestions or tricks on getting the wires thru the bars having no luck myself
Old Jun 14, 2009 | 07:19 PM
refuzeandrezizt's Avatar
refuzeandrezizt
It was a major PITA. My advise, LOTS and LOTS of dish soap. That ended up being the best thing for me. Good luck!!
Old Jun 14, 2009 | 07:25 PM
Alien Spyder's Avatar
Alien Spyder
Have you heard of using a string with a nut tied onto it?
Just drop the nut into the bars and then jiggle it around until it pops out the hole by the grip. Tie the string around the wire and pull it through. You can use some silicone spray or soap if it's really tight.
I'm on my third set of bars and this trick worked every time.
Good luck!
Old Jun 14, 2009 | 07:29 PM
refuzeandrezizt
Yeah, I had to do the nut trick as well on one side, since the crappy string they had in them broke as soon as I started to pull through. Very good advise!!
Old Jun 14, 2009 | 07:55 PM
Zacharia_11's Avatar
Zacharia_11
I used floral wire from walmart and a bottle of hand soap. PITA!!!
Old Jun 14, 2009 | 07:58 PM
Poorguy's Avatar
Poorguy
It can be simple. Here's how we do long conduits regardless of length. You only need to make sure your getting suction.
Tie a plastic bag to a string. Stick in one end of your pipe and suck it through with a vacuum. I can't see why this wouldn't work on pipes and I've heard it done there as well.
Old Jun 14, 2009 | 08:18 PM
Cheesecake's Avatar
Cheesecake
+1... with maybe some better string...
I have done several bikes and had no issues....
is there a particular issue you are having?
Old Jun 14, 2009 | 08:51 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
String, Nut, Beer, Soap, Cuss.
Repeat a few times and then try the Electricians trick posted above.
I know I'm gonna try that later this week.
Beer, Shop Vac, Plastic bag, string, Cuss....Blame on Obama?
Old Jun 14, 2009 | 09:04 PM
bensonjv's Avatar
bensonjv
Similar to the plastic bag method, you can push string through using an air compressor. Tape off all ends except the bar end you re working from and the outlet hole. Air will feed string through hole.
Of course you still have to contend with pulling wires through. On my apes I had limited trouble pulling through with only minor silicone lube required. On pullback drags with integrated risers I had more difficulty. To make life easier I stripped off outer insulation, leaving about +1" on the controls side and an extra 1" on the bottom of the bars exit point. That leaves enough to stick into the bar hole and prevent chafing but eliminates the need to have to pull all that bulk through the bars.
Old Jun 14, 2009 | 10:41 PM
oct1949's Avatar
oct1949
never tried it, but I'll bet Ur better the next time...
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
