A question for experienced bikers
Old Jun 21, 2009 | 10:42 PM
Gunslingertom's Avatar
Gunslingertom
Default A question for experienced bikers
Hi. I have a question for you guys that have ridden for a long time.
Why does it seem like every used Harley has had some or a lot of engine mods? I mean, will a factory Harley motor not last for 100,000 miles? Or is it just that everyone that has one, wants a hotrod? And it seems more prevalent on softail models.
Any insight?
The reason I ask, is because I'm shopping for a softail and it seems like every one of them has either upgraded cams, been stroked, or a has whole new S&S motor, etc, etc. So it makes me wonder if the Harley motor is junk. I mean I can understand accessories to make it look better, although sometimes enough is enough, but why all the motor mods?
Old Jun 21, 2009 | 10:47 PM
oct1949's Avatar
oct1949
The reason is that the EPA has choked the motor down so much that the power is way down where it should be. if not for the EPA's laws, we wouldn't have to do some things to get the motor to run free and help cool it back down. Then HD could use different parts that would be better.
thats why we put pipes, A/C, cams in them..
Old Jun 21, 2009 | 10:59 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I mean ditto. The reason a lot of bikes have upgraded cams is that the twincam 88's (2000-2006) have a poor desing for the cam chain tensioners and they can wear out and grenade your motor. Some people want more power. I found a used bike that had a stock motor and got that.
You gotta let the motor breather and get some more air into it to get a little more power and also adding exhasut to that combo can pep it up and will make it sound like a Harley. A stock Harley is incredibly quiet now.
Old Jun 21, 2009 | 11:08 PM
BoomerBob's Avatar
BoomerBob
It could be that's all that's on the market right now for some odd reason. I would stay away from strokers even though the new TC96 is a factory stroker. It tends to cut down on engine life. I would embrace a TC88 that has a 95" kit with decent cam as you will see long life and good performance from it.
Yes; the cam chain tensioners are an issue but not much of one if they are checked every 30k miles or so and replaced as needed.
The nice thing about buying a used bike is that it usually has all the stuff done to it that most guys would want to do anyway. Naturally the cosmetics are a different story. Part of the fun of Harley's is to personalize them the way you want to.
Old Jun 21, 2009 | 11:39 PM
Gunslingertom
I understand the breathing problems. That makes sense. I was afraid of that about stokers though. I found a stroked 1991 FXSTC. It's a nice bike and the price is right, but I'm afraid it won't get me home.
Old Jun 22, 2009 | 07:03 AM
tk353's Avatar
tk353
a lot of the mods were done to make the bike personal. once you own a harley you will understand
Old Jun 22, 2009 | 07:07 AM
BigGdawg's Avatar
BigGdawg
They need Stage I - pipes, unrestricted air cleaner, and SERT to run like they're supposed to.
Old Jun 22, 2009 | 07:19 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
A stock Harley engine will last longer than you might think with proper maintenance. But like has been said its also been choked down something awful by EPA regs.
If they have a serious 'problem' its the inherent design flaw of the V-Twin layout. Its not a truly balanced engine system like say a BMW's Boxer layout.
Even with the balancers of the "B" motors, its going to be forever cursed with the uneven firing order that is both its downfall, in that its impossible to eliminate all vibration, and its blessing in its that very same uneven firing order that gives us that unique Harley sound.
Personally I have never understood the logic of trying to get huge HP and Torque numbers from one. It accelerates the wear and tare on the engine as fast or faster than it does the bike.
If I wanted a bike that will challenge the world speed record every time I climbed aboard. I would have bought one of those nasty little rice rockets that come off the dealers showroom floor weighing 25 or 30% less, have much bigger brakes, and engines that are pushing or exceeding the 200 hp mark.
But moderate improvements in a Harley's breathing can yield promising returns with little or no extra stress and if its ridden without trying to break the land speed record all the time those same improvements can actually help it last longer.
Because you don't need to jack the manifold pressures up (open the throttle) as far to get you going or keep you going down the road. Your not stressing the hell out of it as often or as long.
So don't be afraid of a bike that's had some modest engine 'improvements', be more concerned with what kind of improvements were made, how it was ridden, and most importantly, how it was maintained.
imrotton2's Avatar
imrotton2
i got over 50k miles on my 103"stroker...it will get yoiu there and back .... heck ,i got 145k miles on the bike rite now... very reliable bike
Old Jun 22, 2009 | 09:10 AM
Gunslingertom
I did some lurking around several different Harley forums and this is why I chose to join this one. Thank you for the detailed explanation.
