Have a problem...
Old Jul 2, 2009 | 12:58 PM
mjp0310's Avatar
mjp0310
Default Have a problem...
My NT has 250 miles on it. Just got a V&H BR 2-2 exhaust. I was going to put it on yesterday when I got home from work. I took the stock exhaust off and saw a mess at the rear exhaust port. I looked at the outside of the cylinder head and noticed a build up of carbon. The front cylinder is clean. The front exhaust flange is clean too but the rear exhaust flange has a build up of carbon and is completely black. You can see it in the pics I attatched. When I purchased the bike, I noticed a an unusual sound and the dealer told me that it was a normal sound and I didn't have anything to worry about. Well....Not very happy.
Attached Thumbnails Have a problem...-106.jpg   Have a problem...-108.jpg   Have a problem...-110.jpg
Old Jul 2, 2009 | 01:00 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
If it bugs you clean it off or send pics to the dealer and see what they say if it is still under warranty. It looks okay to me.
Old Jul 2, 2009 | 01:26 PM
Carmell RKC's Avatar
Carmell RKC
The sound you were hearing was an exhaust leak. I can see the carbon deposit on the head around the flange studs. Replace the gaskets and torque things down properly, you should be good to go.
Old Jul 2, 2009 | 01:47 PM
WFA's Avatar
WFA
Smile
Originally Posted by carmell rkc
the sound you were hearing was an exhaust leak. I can see the carbon deposit on the head around the flange studs. Replace the gaskets and torque things down properly, you should be good to go.
imo...carmell rkc is right on the money. Clean it up, put your new stuff on with correct installation of the gasket and torque specs. Ride on...
Old Jul 2, 2009 | 01:56 PM
priceamp's Avatar
priceamp
I don’t understand. Why is this ok? It looks like an exhaust leak to me. If I read/here one more story where the dealer says, “it’s normal”, I’m going to puke. Bottom line, buy a service manual, torque wrench and teach yourself how to work on your bike, frick’n dealers. It’s ok my azz. Clean that port up and use new exhaust gaskets and then mount your new pipes. Always clean the ports and exhaust studs when re-installing pipes. JMHO.
Old Jul 2, 2009 | 02:08 PM
rbabos's Avatar
rbabos
Clean it all up, install a new cookie and it should be fine. Looks like it was a leaker from the factory with bad seal install
Dealers blow, so get the manual and life will get much better for you.
Ron
Old Jul 2, 2009 | 04:11 PM
back again's Avatar
back again
spend the extra couple of dollars and get the Screamin Eagle gaskets.G.
Old Jul 2, 2009 | 08:20 PM
bigoscycles's Avatar
bigoscycles
It's fine just do what everyone else said. I would check the nuts every so often and make sure there tight.
mupepe
Feb 23, 2015 09:26 PM
gnirtsnod
Nov 6, 2012 09:09 PM
ttopbandit
Sep 12, 2012 08:06 AM
kawsakimx6
Feb 9, 2008 03:50 PM
Sporty12C
Aug 31, 2006 06:51 PM
