Comp ratio on 95" kit
Old Jul 2, 2009 | 11:55 AM
Lundee's Avatar
Lundee
Default Comp ratio on 95" kit
Just curious if a 9.5 or 10.5 is better on a 95" kit. Planning on jugs and carb this summer and cams, heads this winter. Thanks
Old Jul 2, 2009 | 12:31 PM
XARAN's Avatar
XARAN
You need to look at what you want for end Hp/Tq, top end rpm s or more low mid range power and then make a decision on a cam choice. Cams are greatly effected by compression ratio. In general a low to mid range rpm cam will work well with the lower compression and a mid to top end range cam needs more compression.
Old Jul 2, 2009 | 12:41 PM
Lundee's Avatar
Lundee
More reliability, mid range power. I do alot of road trips. Plus a jockey shift probabley gets a little scary w/ to much bottom end.
Old Jul 2, 2009 | 03:54 PM
beaureed445's Avatar
beaureed445
I'd try to set it around 10:1. Fuel quality isn't getting any better, and you don't want to run into a pinging problem.
Old Jul 2, 2009 | 08:23 PM
bigoscycles's Avatar
bigoscycles
For reliability I would stay around 9.5.1 and do a bolt in cam. You can go a little more agressive with both and be reliable. A good set of heads will make a good bit of difference.
Tattooed Mick
Engine Mechanical Topics
36
Sep 14, 2018 12:42 AM
Night Stalker
Oct 3, 2010 10:17 PM
coot34
Sep 19, 2008 06:35 AM
FXST
Aug 30, 2008 07:22 PM
old558
Jan 23, 2008 10:51 PM
