Cam Mods for 95 Cubes.
Old May 5, 2007 | 07:28 AM
FXST's Avatar
FXST
Default Cam Mods for 95 Cubes.
I have a 95 kit with flowed heads. I am thinking of fitting S&S gear driven 510 cams. What type of cams have you guys fitted to your 95 cube engines?
Cheers...
Old May 5, 2007 | 08:44 AM
jimb's Avatar
jimb
Default RE: Cam Mods for 95 Cubes.
SE 203.At least 1 person will say they suck but I'm pretty happy with the way it runs.
[IMG]local://upfiles/11733/8ACDEB75751943EAB13FC07FAC445A38.jpg[/IMG]
Old May 5, 2007 | 09:08 AM
bobros's Avatar
bobros
I opted for the Andrews 26g which are popularfor low/mid range torque.
Old May 5, 2007 | 10:01 AM
George C's Avatar
George C
204..
Old May 5, 2007 | 03:49 PM
FLSTI MARK's Avatar
FLSTI MARK
2nd Gear
I just picked mine up with s/e 251 cams ........ good all the way through but a really nice fat mid range! I really have to hang on now!!!
Old May 7, 2007 | 12:40 AM
jeepster09's Avatar
jeepster09
I like the Kuryakyn packages....other combo's did not work as well. Go to there web sight and look at the Crusher Kits. Just keep in mind what your final outcome is that you are after....so you dont have to buy parts twice that may not be compatable with each other.
Old May 7, 2007 | 07:07 PM
heavypic's Avatar
heavypic
04 Fat Boy with 95 kit, Mikuni carb and SE AC kit...installed the the 251 mid cam too...it has about the same lift as the high-end 257 cam but with less duration...nice mid-rpm perfomance...the mids are were most bikes spend most of their time...that sold it for me....and having a little extra performance 2-up.
Old May 7, 2007 | 10:56 PM
candyx's Avatar
candyx
S&S 570G stock lifters adjustable pushrods and roller rockers. 10.5 pistons, jerry branch head job HD Race Tuner V&H pipes
Old May 7, 2007 | 11:17 PM
sadavis73's Avatar
sadavis73
I just installed the 585 g kit, i have a 95 inch with ported cylinders heads with 10.5:1 pop ups, roller rockers, vance and hines big radius with a power commander with a 50 shot of nitrous. We are going to put it back on the dyno this weekend and retune it, it made 94hp without the portwork and with a set of 204 cams and 9.5:1 compression. I am looking for around 110-115 on motor and 140 or so on the bottle, I will post the results, i just finished the build today here is a pic of it in progress, looks sick
[IMG]local://upfiles/30129/D856E127C8E749B79354CFA963EE1E33.jpg[/IMG]
Old May 8, 2007 | 12:42 AM
HOGWYLDPR's Avatar
HOGWYLDPR
Just finished my 95" build. Running Andrews 32g cams, HTCC heads, high comp pistons, 10.5:1, DTT ignition, SE clutch spring with VPC, 3.37 gearing, Mikuni 45mm carb. Haven't had much time to ride due to weather, but initial impression is WOW! Can't wait to get break in done so I can get on it.
