i've got a few dollars saved up that my wife doesn't know about so i'm going to put them in my bike. but i'm not sure what i want to do next.
1. iso hand grips. right now both of my grips spin like a throtle and they are getting kind of old and nasty
2. smooth hd head light. in 03 they had the textured ones but i like the new smooth look a lot better
3. lower the bike. if i lower it do i need to lower the front and back or just the back?? and i've seen progressive kits for the front where you don't even have to drop the forks...anyone used this kit? and what did they think? and are there any rear bolts for the rear that are better than another? and do you have the pull the rear shocks??
4. ??????????you tell me??????????
First off we will have to draw up a contract. As your Consultant I require 20% of all hidden savings
That 20% To be deposited into my account before the initial meeting to discuss the way said savings should be spent.
Drop it, the dropin springs you still have to either remove the tubes or slide them down some to change the springs. Lowering it will give you the most bang for the buck I think
my adress is 650 ogden ave
chicago,il 60432
make check out to m i k e
thank you nice summer
sounding like i should lower it. should i just lower the rear or both the front and the rear?? and are any of the lowering bolts better than another??
