ENGINE MODS... Worth it?
http://harleytechtalk.net/htt/index.php?topic=11806.0
OP, if nothing else, be sure to do lots of research and on more than one forum if you decide to do a build!
A. That dyno graph is a STD, graph meaning its not SAE corrected. So in all likely your pulling peak numbers of around 75hp/90tq.
B. The majority of your gains come from your retune, pipes and AC
C. The 21 cams are VERY MILD and very similiar to stock cams. Your probably only gaining a few foot pounds of torque and hp from just the cams ALONE.
D. The important Andrews cam specs: 10/30 40/08 .473 18 degrees overlap 220/228 duration
Stock: 02/34 42/03 .490 5 degrees overlap 216/225 duration
With the above specs there is NOT MUCH DIFFERENCE between them, very similiar, the 21 will add a bit, but not that much in reality.
Again I have seen big bore 95"/97" kits with stock cams, a good tune, pipes and AC put down a real 90-100 foot pounds of torque(and lower in the RPM range), with a bit more top end power.
THat being said, you do have what looks like a good tune and a very respectable dyno plot, but I have seen better numbers(SAE corrected) from dyno sheets on well tuned 95"/97" setups using stock cams and heads. They have a displacement advantage along with a mild bump of about a point in compression which along offsets a mild cam swapout.
Hell I'll even add that your gaining some hp/tq numbers from the fact that your running SPOKED rims. The reduced rotational mass itself from your wheels will gain your hp and tq. over typical rims that many people run.
I think I would be happy with doing a simple reliable 103 stroker with a fixed up crank that can do 110/120 as any more would have me wadded up in a ditch (One handed jockey shifting at WFO is....Crazy!) but it never hurts to dream a little?
Custom spec'd cam grind to my specifications:
Intake Open 17 close 41 .595 lift 238 duration 102 LC 33 degree overlap
Exhaust open 46 close 16 .595 lift 241 duration 105 LC
The cams also used and advance profile with a slow initial opening to maximize intake charge at lower rpms and then open very fast to stop reversion. Allows for excellent punch at low rpms and keeps gunning till my 6200 redline.
Stop being selfish and greedy.
Post the run.
So in reality, that chart is 0.99 X uncorrected HP & Tq, which means that it's a lower number than uncorrected, and it's got the highest smoothing number, which means that the peaks and valleys are flattened out.
At least that's what the chart says....Since it's not mine, it sure isn't worth bickering over with you.
