fxcwc 3" forward control extensions
Old Jul 19, 2009 | 08:03 PM
fastcash0523's Avatar
fastcash0523
Here's mine. Arlen Ness 3" extensions. Came with the extended brake line and shifter extension.
Attached Thumbnails fxcwc 3" forward control extensions-user58489_pic29541_1237823725_thumb.jpg   fxcwc 3" forward control extensions-user58489_pic29544_1237824140_thumb.jpg
Old Jul 19, 2009 | 08:20 PM
nytrn's Avatar
nytrn
Am also looking at getting the Arlen Ness 3" extensions for my 09 Night Train. So if u purchase this kit http://www.arlenness.com/p-1068-exte...9-softail.aspx they just use your old controls? Then later can u just add pegs/shifters to them?
Old Jul 21, 2009 | 06:53 AM
fastcash0523
Yes, that is correct. Looks like the same kit I put on mine.
Old Jul 21, 2009 | 12:43 PM
RocketRocker's Avatar
RocketRocker
240- I just installed some kuryakyn cruise mounts....check out the pics in my garage...these things are great...changes the whole ride
Old Jul 13, 2010 | 05:56 AM
Bryce05's Avatar
Bryce05
Originally Posted by rockerheadsteve
Anytime, I believe they are referring to the feelers that are on our factory pegs that keep you from scraping the primary and pipes. After market pegs and pedals should bolt up fine. I wish they would make some cool after market pegs with feelers. The feeler pegs do help to keep from leaning the bike too far. I've heard seen several posts from owners with after market foot pegs dragging their primary's and pipes, ouch! Your stuff should bolt right up. If you choose to go the cheaper route, you'll have to either paint or chrome the extensions the others are suggesting. I seen one that looked like it might have been aluminum or anodized, looked ok from a distance, but looked like crap up close. Hope this helps.
Is this problem just with the rocker? I'm thinking of doing the 3"
on my 05 standard
Old Apr 25, 2011 | 09:46 AM
1caguas1's Avatar
1caguas1
6th Gear
fastcash are the extenders you use the arlen ness part # 7-611 pleas let me know, I like these and want to make sure they fit my 09 Rocker C
Old Apr 25, 2011 | 03:12 PM
870's Avatar
870
Originally Posted by Texasboom22
240,
I'm also 6'3" and recently put an Arlene Ness 3" extension on my NT. It completly changed the feel of my bike, for the better. Not sure if they have one for the Rocker but it's worth the look.
im looking at putting the same kit on my NT do you have any pics of them on your bike?
Old Jul 25, 2011 | 10:07 AM
chopperguy2009's Avatar
chopperguy2009
1st Gear
whats up guy i have the same problem im 6ft 1 and i found them but they come in black only. im from brooklyn new york and my mechanic said they run about $300 with out the labor. check out my social group its called brooklyn bikers. ride safe
Old Jul 25, 2011 | 01:35 PM
TalonIILM's Avatar
TalonIILM
Smile Rocker FWD Controls
Originally Posted by 240rear
Thanks for the info. I want to use the Aftermarket foot pegs, shifter and brake pedal I already have but it says you can't. Don't understand? Any ideas why?
The foot peg mount pin is a larger diameter on Rockers, Blacklines and Sportsters than the other's. You can use any peg you want just drill the pin hole out to fit.
I looked at all the extension plates out there for Rockers/ Softails and decided to go with the H-D brackets vs plates. Costs more but I wanted more than plates. I'm using the large Diamond Black pegs, fitted to the stock/ original pins. I also found a Rocker specific peg w/ feeler on the H-D web site. BTW looks like the feelers are threaded on, thus replaceable.
Additionally, the H-D extension brackets fit both Rockers and Blacklines, not positive about the Sporties.
The parts guy at my local H-D dealership and I took the pegs and compared them to the Rocker and Blackline to see why the cataloge said no fit... it's just the pin. As far as we could tell ... Still have some of the stuff on order. Soon as I get everything mounted up I'll post pics.
TIILM
50500035
Fits '11-later XL883L and XL1200C, '10-later XL1200X, '08-later FXCW/C, and '11 FXS models.
Old Mar 10, 2013 | 02:49 PM
Hwnorth's Avatar
Hwnorth
I have a 2008 Rocker, Im 6' tall and went with the Arlen Ness 3" extensions. I would think 2 or 2.5" would have been enough, but I like how stretched out I am.
I bought mine off ebay for $175, and came with extended brake lines and shifter rod.
As far as changing these, skill level I would put at a 4 out of 10. Pretty easy to change out and follow the instructions.
gasman1620
Mar 16, 2014 09:46 PM
r0ck3r
May 29, 2010 09:33 AM
rocker0984
May 15, 2010 10:20 PM
billtrip
Jan 24, 2009 11:23 AM
The Fallen
Jul 4, 2008 09:32 AM
