Heritage Softail Speedometer Problem
Old Jul 30, 2009 | 06:42 PM
paulmack's Avatar
paulmack
Stage III
Default Heritage Softail Speedometer Problem
I have a 2006 Heritage Softail Classic and the speedometer is intermittent. It will work for a couple of days and then go dead for up to a week then work again for a little while. The odometer works fine, the signals work fine and the auto cancel works fine. Where should I look for the problem. I cleaned the speed sensor and it worked for a dat or two and died again.
Old Jul 30, 2009 | 06:47 PM
BigMike17's Avatar
BigMike17
You might need a new speed sensor -
Old Jul 30, 2009 | 07:04 PM
FLTRU4ME's Avatar
FLTRU4ME
jiggle the ignition switch and see if it starts working. If it does it's in the switch.
Old Aug 2, 2009 | 01:05 PM
paulmack's Avatar
paulmack
Stage III
Tried the switch. When I turn the switch to the accessory position the needle on the speedo goes all the way to the right and stays there even when I turn to the off position. I have to toggle netween off and ignition to get the needle to go back to zero but the speedo still doesn't work.
TheSnakeBite
Apr 30, 2015 10:12 PM
Toolbndr
Dec 9, 2012 07:53 PM
DaddyKnuck
May 22, 2011 04:30 PM
ben8ent
Jan 17, 2008 02:44 PM
sddyna
Sep 13, 2007 07:05 AM
