Wide (rear) tire up front?
Old Aug 3, 2009 | 08:13 AM
handyhoward's Avatar
handyhoward
Originally Posted by Plasteredcat
Bump on this thread .... I would think that if anyone would know how fat you can go on the front it would be Exile. Seems they have been doing this the last 10 years. I think there bike style was ahead of there time. They were building fatty/bobbers when everyone else was building stretched out choppers.
If you modify the front end... you can virtually put anything you want out there... I think we were talking about stock front ends.
Old Aug 3, 2009 | 10:04 AM
grimm's Avatar
grimm
i'm running a 160 deuce rear wheel and tire up front. as advised, the tire is reversed and i have had no problems at all with it's handling. just take it somewhere where they can machine the right spacers so as to center the tire and space out the caliper accordingly and you should have no problems. here's the front shot of mine with the 160...
grimm
Attached Thumbnails Wide (rear) tire up front?-the-deuce-2.jpg   Wide (rear) tire up front?-the-deuce-1.jpg
Old Aug 3, 2009 | 11:14 PM
michael95688's Avatar
michael95688
Exile runs a 200 on most of their big tire bikes. I didn't call them to see if they were rears but I have to believe they are. I'm really struggling with the idea that a tire designed to handle 100+ HP doesn't have what it takes to turn slightly left or right (most turning is leaning). I can easily imagine a "rear" tire doesn't handle as well as a front given the load rating and HP and torque applied.
It doesn't matter, I decided to go with the 130/90/16 off the Fatbob. Thanks for the input.
Old Aug 3, 2009 | 11:44 PM
plane's Avatar
plane
Maybe the front/rear designations are there so you don't inadvertently put a front on the back of your bike.
I can see no reason why a rear tire wouldn't work just fine on the front, assuming it fits. Heck for all I know I might even be safer. I'd have no fears of doing it on my own machine.
Not sure about the turning it around backwards. If the tread design was made to turn a certain way for wet weather applications turning it around might not be the best way to go.
Old Aug 4, 2009 | 06:52 AM
robc234's Avatar
robc234
if you look at the tread pattern of the metzler me 880 front versus rear the pattern is identical only reversed. same with the avon venom and the dunlop 407
HDMLNIUM
Jun 19, 2016 05:49 PM
cpc0812
Jan 17, 2015 08:50 AM
emperor wurm
Jan 27, 2012 12:45 PM
Seascape
Sep 4, 2009 11:15 PM
Sincecrazy
Jan 31, 2005 08:52 AM
