adjusting softail shocks
Old Aug 3, 2009 | 09:13 AM
James Carroll's Avatar
James Carroll
6th Gear
Default adjusting softail shocks
Whe trying to back off the jam nut the whole shock turns. Any suggestions?
Old Aug 3, 2009 | 09:42 AM
TIPN8R's Avatar
TIPN8R
You need a spanner wrench and also try the flat sides of the piston to grab it.
Old Aug 3, 2009 | 10:03 AM
chrome-dome-dave's Avatar
chrome-dome-dave
There are 2 flat spots on the adjustment bolts, hod them and you should be ok. Spanner wrench like said above will make life easier.
Old Aug 3, 2009 | 10:14 AM
WFA's Avatar
WFA
[QUOTE=TIPN8R;5367740]You need a spanner wrench and also try the flat sides of the piston to grab it.
+1...IMO...GOTTA HAVE A SPANNER OR EQUIVALENT TO HOLD THE ADJUSTING PLATE WHILE BACKING OFF THE JAM NUT. MAYBE A SHARP TAP WITH A HAMMER TO THE WRENCH WILL POP THE JAM NUT LOOSE FROM THE ADJUSTING PLATE. AN EXTRA SET OF HANDS WOULD BE HANDY RIGHT ABOUT NOW. KEEP AT IT AND IT WILL EVENTUALLY BREAK LOOSE. BY THE WAY, ONCE LOOSE THE CANISTER AND ADJUSTING PLATE ARE LIKLY TO TURN TOGETHER WHILE YOU ADJUST. THAT IS NOT A PROBLEM!!!
Old Aug 3, 2009 | 10:49 AM
dennyo's Avatar
dennyo
AND make sur U mark um so U no how far U turned-um
Old Aug 3, 2009 | 01:37 PM
Dorkman's Avatar
Dorkman
Best description and photos I've seen re adjusting shocks:
http://www.fatbillscustoms.com/
Old Aug 4, 2009 | 11:29 AM
James Carroll
6th Gear
Default Softail shocks
Have the spanner. Thanks for the tips. I'll try when I can get away from work. Will report back.
Old Aug 4, 2009 | 11:57 AM
mstakern's Avatar
mstakern
Thanks Dorkman that page is very helpful.
Old Aug 4, 2009 | 02:38 PM
WFA's Avatar
WFA
Originally Posted by mstakern
thanks dorkman that page is very helpful.
Thank Fat Bills Customs ! I do every time i refer to his stuff!!
Old Aug 7, 2009 | 11:18 AM
James Carroll
6th Gear
Default Holy crap!
After loosening the jam nut I put a 9/16 wrench on the flats of the stem and braced it against the frame. I couldn't budge the adjuster plate with the spanner so I had to use my foot on the spanner! It still didn't want to turn with pretty firm pressure. I didn't want to push any harder cause I thought the bike would tip over on me or I would at least loose some skin. Maybe it needs anti-seize or WD40?
