odd hot engine starts
Old Aug 4, 2009 | 07:16 AM
tk353's Avatar
tk353
that year can be carb or Fi. sound like fi
Old Aug 4, 2009 | 09:07 AM
schumacher's Avatar
schumacher
so nobody knows what that short whirring noise is?
Old Aug 4, 2009 | 09:17 AM
Robottom's Avatar
Robottom
Do you have an electric fuel pump or is it gravity feed? I don't know about the carb'd models, but the EFI's all have electric fuel pumps. Most make a wirring noise when you hit the run switch with the ignition on.
Old Aug 4, 2009 | 09:27 AM
anubisss's Avatar
anubisss
Continuum transfunctioner is the issue. http://www.urbandictionary.com/defin...ransfunctioner
Old Aug 4, 2009 | 11:27 AM
rbabos's Avatar
rbabos
Generally hot start issues with carbs is from fuel boil over from heat. Carb heats up from the engine and if the float level is at a high setting this fuel expands from the heat and runs into the cyls basically floading the engine. When the engine is running, the carb will actually be cool. Lower float setting will help, or even the angle of the bike when the kickstand is down has an effect on how much fuel will run in from this boil over.
Ron
Old Aug 4, 2009 | 11:30 AM
schumacher's Avatar
schumacher
It has a choke and petcock. Looks like a carb on the right side.
Old Aug 4, 2009 | 11:47 AM
tk353's Avatar
tk353
then it is carb with a strange noise. ask the dealer and let us know. we can also tell from the vin number what it has
Old Aug 4, 2009 | 02:03 PM
Mike NY's Avatar
Mike NY
That whirring sound is just left over in your head from your Honda bike days when you had a radiator fan...
J/K...
Mike
NY
Old Aug 4, 2009 | 02:32 PM
tk353's Avatar
tk353
tell us where the noise comes from. remove some fuses until you find the one the stops the sound from happening the first time
Old Aug 4, 2009 | 03:53 PM
fastcash0523's Avatar
fastcash0523
In my opinion, I think the combustion level is higher on the FI models when they are warm. My Rocker does it some, but it seems like it is worse on warmer days. That's just my opinion, I could be wrong.
