Clutch question
Old Aug 16, 2009 | 10:52 AM
chordstrummer's Avatar
chordstrummer
Default Clutch question
Just did the 10k service on my '09 Deluxe, and all went well, except ...
I don't recall if it did this before or not: When the bike is idling in neutral, and I apply just enough pressure on the clutch lever to take up the slack in the cable (but before I'm actually pulling on the lever) I can feel (and see) it pulsing/moving a little.
Anyone know if this is normal, or did I manage to adjust the clutch pack incorrectly? I do have the service manual and followed the adjustment procedure by the book. The only thing being, the bike was not completely cold -- I'd ridden it about three hours before. Figured it was close enough to "room temp."
Looking for opinions before I go get another derby cover gasket and redo it (hoping I don't need to).
Appreciate any info.
Old Aug 16, 2009 | 05:13 PM
chordstrummer
Also wanted to add that I've adjusted the clutch once before and honestly can't remember if it did this before.
Any help on this?
Old Aug 16, 2009 | 05:24 PM
plane's Avatar
plane
my 08 Fatboy does it too. I just figured it was normal.
Old Aug 16, 2009 | 05:33 PM
Dorkman's Avatar
Dorkman
Sounds like what you are feeling is just feedback from the clutch, since you have taken the slack out of the cable.
When underway, if the clutch is engaging when the lever is around 1/3 out, and starting to disengage when the lever is pulled in around 1/3, you should be OK. These are approximations and will vary if the bike is hot or cold. As long as you made the proper adjustment down below, and at the lever end, you are OK.
Old Aug 16, 2009 | 09:11 PM
keno's Avatar
keno
I don't feel pulsing in my clutch lever.
Old Aug 16, 2009 | 11:55 PM
chordstrummer
Appreciate the comments, everyone, thanks.
Doesn't seem to affect engagement at all -- it's working great.
Old Aug 16, 2009 | 11:59 PM
qwispichkn's Avatar
qwispichkn
If you followed the manual, you should be okay.
When I adjusted mine I was wary too if I did it right, but been working fine.
overthehill?
Oct 4, 2013 09:18 AM
Govno
Apr 20, 2013 12:25 PM
RZA
Feb 3, 2012 02:46 PM
r8rs4lf
Aug 15, 2009 10:26 PM
Costnsg
Feb 28, 2009 08:56 PM
