Grease
Old Aug 17, 2009 | 10:20 PM
SargeKFFK's Avatar
SargeKFFK
Stage II
Default Grease
My 03 fatboy is leaking grease from the lower steering tube. Is this common and if so how do I stop it. The crap keeps landing on my tank and I hate cleaning it.
Old Aug 17, 2009 | 10:37 PM
RocketRocker's Avatar
RocketRocker
Its normal....it will eventually stop and then it will be just a little bit. That stuff used to splash out everywhere but I think it was just excess grease that was put in there.
Old Aug 18, 2009 | 12:31 AM
JayDee5150's Avatar
JayDee5150
Normal...I recently greased my neck bearings and they've been oozing out of the bottom of the neck every now and then...hot weather gets it flowing a bit more.
It will stop with time...
Old Aug 18, 2009 | 02:51 AM
StreetGeezer's Avatar
StreetGeezer
Had the same problem when I ignored warnings from other forum members about using grease other than recommended by Harley. I used the lithium based (yellowish) grease and it just kept coming out and getting all over my engine. Recently went and purchased some Harley grease to find out what it is (it's the blue-green stuff). Went to the local Home Depot and got a three pack of grease in tubes the right size and the same type as the Harley stuff for my grease gun and pushed all of the lithium stuff out. Been a lot better since.
Old Aug 18, 2009 | 07:00 AM
tk353's Avatar
tk353
normal for a while but then should stop. i pay to have the adjustment done at the same time
Old Aug 18, 2009 | 09:12 AM
mke125125's Avatar
mke125125
I put royal purple synthetic grease in mine last time. it has a much higher separation temp than regular grease. its pricey but atleast it doesnt turn to oil when the temps rise. I havent had a drip since.
Old Aug 18, 2009 | 10:20 PM
oct1949's Avatar
oct1949
normal at the reg grease time..
Old Aug 19, 2009 | 04:35 AM
hpfatboy's Avatar
hpfatboy
Normal, they say pump till it comes out of neck bottom. Dont believe it needs to be done that often.
Old Aug 19, 2009 | 10:25 PM
SargeKFFK's Avatar
SargeKFFK
Stage II
Thanks for the info. Saves me a trip to the shop.
Old Aug 20, 2009 | 06:43 AM
tk353's Avatar
tk353
i also go to the shop because they TQ the bearings. about 1/2 hr labor every 20,000 miles
5150northrider
General Topics/Tech Tips
Aug 10, 2016 12:42 PM
eddie57
Sep 11, 2013 06:55 AM
duluth
May 15, 2012 02:27 PM
IndyClassic
May 24, 2011 08:17 AM
ajay450
Mar 12, 2009 08:43 AM
