Front end lowering advice
Old Sep 9, 2009 | 09:57 AM
twisted125's Avatar
twisted125
haha, its like the old timer hangin upside down blindfolded to assemble his 45, why not?
ok, the bolt I was thinkin was #27. It seems that it is more of a set screw?
So, you have to slide the tubes down the tree to get at the insides? This doesn't seem like such a painless process anymore.
Old Sep 9, 2009 | 10:07 AM
2DAKERB's Avatar
2DAKERB
Check these out.
http://www.youtube.com/watch?v=kZGHZFLk23k
http://www.youtube.com/watch?v=RtwCNSclmYs
Old Sep 9, 2009 | 10:09 AM
twisted125's Avatar
twisted125
dammit, my work has watchdog that blocks out youtube, ill have to look at em later. Daker, did you do the "drop in" kit?
Old Sep 9, 2009 | 10:21 AM
2DAKERB's Avatar
2DAKERB
I used the Burley kit.
Old Sep 9, 2009 | 10:34 AM
twisted125's Avatar
twisted125
estimated time you spent on it??
Old Sep 9, 2009 | 11:59 AM
boosteddelslow's Avatar
boosteddelslow
After watching those two videos everything makes sense now. It is not really a hard job but the whole front end has to be taken apart so it is far from a drop in kit. The only thing that doesent make sense to me is that you have to trim the preload spacer. He said to trim it a little bit higher than the for tube when it is fully extended but to me a little bit is like a 1/4 inch. It looked like his trimmed peice was longer than the orginal. But maybe the fork tube dropped down a little bit. But good video.
Old Sep 9, 2009 | 12:31 PM
twisted125's Avatar
twisted125
I will have to use my works facilities for this as I am ill prepared at home. Any ideas on how long this should take . . . in a "perfect" world? so I can plan for when I get mine.
Old Sep 9, 2009 | 12:40 PM
2DAKERB's Avatar
2DAKERB
1st time 2- 2.5 hours, 2nd and 3rd time 1- 1.5 hours tops.
Old Sep 9, 2009 | 12:45 PM
twisted125's Avatar
twisted125
not bad at all, I can swing that. Thanks man
Old Sep 9, 2009 | 12:57 PM
bgibbster's Avatar
bgibbster
Boosted,
the drop-in kit is the same for all 41mm front ends, so the preload spacer is cut to a specific length depending on what bike you have. On my fxst it says 4 1/2", but that is just where you should start. I adjusted mine to about 3 3/4". The good thing is that it is just PVC pipe so you can always get more if you need it. I am like a couple of the other guys on here and swapped out my fork tubes for the -2 under, and I just dropped the springs in and used a different size spacer.
If you don't already have an front lowering kit I would go on eBay and look up bkrider and buy some -4 under tubes and install those. Mine came with everything you need for the install, springs, seals,retaining rings etc....
