Belt Rub
Old Sep 17, 2009 | 06:46 AM
Remnighttrain's Avatar
Remnighttrain
Stage III
Default Belt Rub
My primary belt is rubbing on my jack shaft it is wearing from the middle all the way over to the inside it is eating it away, I have adjusted belt tention but still rubbing is going on, Its not making no noise but the groves are about gone.is it to tight to loose need some advise.
Old Sep 25, 2009 | 08:08 PM
JayDee5150's Avatar
JayDee5150
My belt rubs on the starter jackshaft as well. It never did it until I lowered the rear 2 inches. Mine rubs the outside of the belt and it is slowly removing the grooves too.
Is your bike lowered?
If it is lowered, it's probably coming from that mod. It it's stock height, it may be an adjustment issue.
Old Sep 28, 2009 | 10:17 AM
dusty2221's Avatar
dusty2221
Mine rubbed on a trip once. Turned out to be the belt was too loose. I would double check your belt. These things are supposed to be pretty tight.
Old Sep 29, 2009 | 06:25 AM
Remnighttrain
Stage III
My bike was lowered ,But I raise it back up and thats when it started rubbing,I did tighten my belt up because I could twist almost 90 degrees, adjusted to a 45 degree twist, Can not tell if it is rubbing no more, But I think my belt got loose when I raise it back up.
cromagnon
May 15, 2023 10:07 AM
Harlay Hawk
May 2, 2021 09:14 AM
zeus33
Jul 13, 2013 05:16 AM
00glider
11
Sep 26, 2007 03:42 PM
hdfxwg85
May 20, 2007 05:07 AM
