Popping during engine braking
Old Sep 19, 2009 | 11:59 AM
Buellrunner's Avatar
Buellrunner
Default Popping during engine braking
2006 heritage pciii porker jacknives
I get alot of popping when I shift down and release the throttle.
Nothing though If I pull in the clutch.
Only on deceleration. Baffles are in. Map is correct.
2 questions.
1. Why does it do this? Is it normal?
2. Is it bad for my motor?
Besides this she runs perfect.
Cheers!
Old Sep 19, 2009 | 12:15 PM
cowboy-bc's Avatar
cowboy-bc
2 questions.
Cheers!
Change the map values in the first column to 1500 rpm to zero
Old Sep 19, 2009 | 12:34 PM
SportsterBob's Avatar
SportsterBob
Small amounts of unburned fuel will ignite inside the exhaust during deceleration and cause the "pop"..When you pull in the clutch lever the engine is drawing in less air and reduces the unburned fuel going into the exhaust...It shouldn't cause damage.
Cowboy is on target.
Old Sep 19, 2009 | 12:43 PM
09_NightRider's Avatar
09_NightRider
you could just stop using the engine as a brake...
in other words wait a little longer to down shift
I know that sounded a little like me being an ***, not meant that way at all.
chris
Old Sep 19, 2009 | 09:27 PM
kentuckydave's Avatar
kentuckydave
Most engines will backfire a lot if the timing is just slightly slow. If remapping doesn't fix it, have someone that knows what they are doing, check the timing.
Old Sep 19, 2009 | 11:17 PM
oct1949's Avatar
oct1949
Mine did it and ended up finding the HD wrench didnt get the mufflers sealed right...
they had to redo them twice and re dyno it toe fix and got 99% of all decell popping out of her...
Old Sep 20, 2009 | 12:23 AM
dkyork's Avatar
dkyork
I went into the mountains today and had a lot of popping going down hills decelerating in gear. I think that's just the way it is.
Dale
Old Sep 20, 2009 | 07:40 AM
tk353's Avatar
tk353
love my thundermax
Old Sep 20, 2009 | 07:45 AM
prodrag1320's Avatar
prodrag1320
what remapping unit are you running?
kirby
vee twin racing
Old Sep 20, 2009 | 08:03 AM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Yup...
And Yup.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
