Rocker headlight bulb question.
Old Oct 19, 2009 | 07:59 PM
Alain's Avatar
Alain
Default Rocker headlight bulb question.
What kind of headlight bulb does the rocker take? Is it H7, H9? Or neither.
Thanks fellers
Old Oct 20, 2009 | 04:51 AM
DECON BLUE's Avatar
DECON BLUE
Should tell in owners manuel, or service manuel.
Old Oct 20, 2009 | 05:27 AM
DragonSlayer08's Avatar
DragonSlayer08
Thanks fellers
The bulb is part number 68329-02, HB2/H4.
Old Oct 20, 2009 | 02:25 PM
pcoakle1's Avatar
pcoakle1
Default Is anyone using a HID headlamp for their Rocker?
Is anyone using a HID headlamp for their Rocker? In earlier post someone said it's stock bulb is: part number 68329-02, HB2/H4.
I used to use HID bulbs in other bikes and want to upgrade the weak headlamp bulb in my '08 Rocker C.
What do you all recommend? I want the brightest possible bulb.
Thanks
Old Oct 20, 2009 | 09:17 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
PIAA has about the best stock sized bulb you can fit into the stock housing with the Sylvania Silverstar running a fair second.
Stay away from the cheap supposedly HID bulbs that are sold on the internet (e-bay in particular). Most are just cheap imitations of the above mentioned bulbs and some can also run hot enough to damage and or warp the plastic reflector in your housing.
pcoakle1
Oct 21, 2009 01:11 PM
NewfieRocker
Sep 26, 2009 03:53 PM
metalheart
Sep 8, 2009 10:35 AM
OregonFXSTC
May 26, 2009 09:49 AM
richy rich
Dec 3, 2008 09:02 AM
