Windshield change for fatboy
Old Oct 21, 2009 | 11:08 AM
ski917's Avatar
ski917
Default Windshield change for fatboy
I have a 07 Fatboy and I will be putting a set of passing lamps on it by December. I plan on going with the style that are on the Heritage/Road King and when I bought my bike new I had the dealer put a detach/ winshield on it. My question is will I be able to use the same windshield when I get the passing lamps installed or will I have to buy a different windshield? I don't have the tools to change my current windshield by modifying my windshield by sutting it and etc. if that's the case.
Old Oct 21, 2009 | 12:35 PM
Wallaby's Avatar
Wallaby
Re: your quick detach windshield, does the H-D accessory catalog say anything like "will not fit with auxillary passing lamp kit blah, blah, blah"? They usually state all the exceptions to fitment.
Old Oct 21, 2009 | 08:17 PM
Grizzbare's Avatar
Grizzbare
It should fit fine I have my 09 set up that way look at the pics in my garage or in my album to confirm
Grizz
Old Oct 21, 2009 | 09:40 PM
KumaRide's Avatar
KumaRide
It will fit, but not the same way as the Heritage shield or FB shield fits for the passing lamps. I did exactly what you are wanting to do. Had the detach shield for no passing lamps and installed the passing lamps. Typically the shield mounts on the "outside" of the passing lamp bracket on the rubber grommets. Our shields will not bend far enough to do this. It is close, but it will not want to stay on and just does not fit right.
For the upper grommet you will need to put it against the forks as usual then add a ~1/2" spacer to compensate for the width of the upper portion of the bracket. If you look at other bikes, you will notice they have a 3/4 spacer between the bracket and the forks. For the lower mount I wrapped some electrical tape at the bottom of the shield mount, not the bracket mount, to absorb any vibration and to keep things from scratching The lower mount will slide right onto the hardware of the bracket, in between the bracket and the fork. You will not be able to use the rubber grommet for the lowers with our shields. When you get the bracket and match it to the forks, this will make sense. When you have everything, get a hold of me and I can get some pics for you.
In the mean time, look at some bikes with passing lamps and notice that the shield attaches on the outside of the bracket.
Or, go get another shield Maybe some one will trade?
Old Dec 24, 2009 | 06:15 AM
ski917's Avatar
ski917
Thanks. Ive got rverything ordered and am getting it intalled this Saturday. I went with the heritage/road glide kit. I will contact you sunday and will post pics of what it looks like.
Old Dec 24, 2009 | 07:18 AM
Kojax's Avatar
Kojax
Cool
I AM GLAD YOU ARE KEEPING THE FATBOY YIPPY merry christmas
Old Dec 24, 2009 | 08:00 AM
Hodgewater's Avatar
Hodgewater
I have a 2007 fatboy, and this windsheild was recommended to me by the dealer, just incase I wanted to put on lamps in the furture.(Windshield -57141-05)
Old Dec 24, 2009 | 12:11 PM
Danny D's Avatar
Danny D
Got the HD detachable windsheild with passing lights on '07 Fatboy. No problemo!
Old Apr 28, 2010 | 09:30 PM
DLMiks2's Avatar
DLMiks2
Stage II
I have an 08 FB. Looking at a RK Windshield. I don't have passing lamps yet. Im thinking about putting spacers on the screws between the forks and the mounting bracket. Anyone have any luck with that. Thanks.
Krugermeier
Dec 27, 2017 12:03 AM
harley0101
Nov 28, 2014 07:16 PM
Das_Fatboy
Nov 24, 2012 12:32 PM
golfblues
May 12, 2011 02:45 PM
RK Scooter
Apr 11, 2010 03:54 PM
