What the hell!? Do I need a tuner?
Situation - My bike is an 07 Softail Standard. Aside from the Hooker Troublemakers, the motor is stock. Stock A/C etc. Upon putting the pipes on, I took it over and got it flashed. It was cool, then I noticed a small flame coming from the tips. As cool as it is to blow flames, its not right. I found that one of my exhaust flange nuts had vibrated loose. Tightened, and its all good. So, a couple months down the road now. When starting it at the house, I can pull out of the drive and start to leave the neighborhood when it seems like its bogged down. I dont go out of 3rd usually, sometimes 2nd when leavin the "hood". I had it die on me once right around the corner from my house. It was acting like a carbd vehicle when you flood the bowl. When on the road, rolling low 50's in 5th, and I go to twist some throttle, it seems like it hesitates. If I go from cruise to almost WFO, it definately lags, then slowly catches up to what my hand is telling it to do. NOT like it used to be. I will admit, I can tend to make myself paranoid when Im riding and I feel something, or hear something that sounds off, I guess Im just noid about hurting the motor if I am truly in need of some tune work.
Question - If I indeed need a tuner, what are the less expensive alternatives. As of yet, I have not begun to **** 20's . . . that I know. So money is DEFINATELY something to consider, as Im sure it is for a lot of people on here. I have found the Arlen Ness Big Shot adjustable tuner, 260. Total Fuel Systems Technologies, Power Commander, V&H Fuel Pack etc. I am a bargain shopper, and an ebayer, but dont want to buy a piece of **** box with wires coming out of it that doesnt work. I've heard good things about RevTech DFO, those can be found for a descent price. All input is MUCH appreciated. I can budget around 2 - 250 bucks for this. What is the best bang for my buck?>??? Thanks guys.
kirby
It should improve things.....
If that's all you want to do, then you can probably get away the flash from HD.....But a good tuner will always dial the bike in perfectly...
Im a bit noid about buyin this off of ebay. It seems it would be real easy for someone to make a "tuner" that doesnt do **** and put your money in their pocket. I guess the best route for me would be to pick up and tuner and put the A/C next on the list. I had a bunch of wants as Im converting my Standard to a "dark" standard. Powder, etc. But its pointless to do that if the bike isnt running right. Needs over wants right now I guess.
Ive flashed from HD twice now. Hasnt seemed to do enough. So I am getting too much fuel, not enough air right? How about the DFO??
Thanks guys.
IMHO, you would do justice by changing the AC first.
Then look up different tuners...Because any mods you do after the tuner will require adjustments to it..
Also look at Fuel Moto on this site and on Ebay for great prices on a power commander
Damn - just looked at fuel moto - didnt realize you can get a PC for 260! Thats a PClll, good enough for what Im doing??
Doing the AC now should bring it close to what HD assumes.
It will most likely still run lean, but you should see improvement right away..
After that, if you still want to put a tuner on there see Fuel Moto.
The PCIII will be perfect....Fuel moto can put a map on there based on what your running for mods.... A canned map is never perfect.....The only way to get it perfect is get some dyno time and have a qualified guy custom map it.....
