I did a search for relocating Fatboy front turn signals and I only found one thread about it with no real answers. I am looking to take out the bottom screw on the fork tins and put the turn signals there. Does anyone have any ideas on what ill need to do that?
Chris
This is a mod I've done to my Fatboy and Roadking. You need a piece of threaded rod the same size as the bolts holding your tin's on,after getting the correct length run a thread die half the length of your rod to match the thread in your turn signal.
You will need two locking nuts per stud to hold everything together.
I have a Kuryakyn light kit for the Fatboy that I bought that comes with halogen lights and the necessary hardware for sale. All interested buyers pm me. Light kit info from Kuryakyn.com. http://www.kuryakyn.com/products.asp?bn=harley&ci=2595
I checked out their website.. yikes. Looks like they have some really cool products but Man their website is really hurting them. Gotta be the worst website I've seen for an aftermarket manufacturer I've seen in a while. If anything, aftermarket stuff like this must have a really descriptive and well layed out site with good pictures. This one has none of the above and any picture links go to nowhere and don't work. Hope they read this.
It's a shame.. Looks like they do have some really cool stuff.. I'm certainly interested. I have a detach windsheild and I'm just interested in getting the signals off the handlebars. I've even seen people mount their signals to floorboards or the frame to get them off handlebars.
I'm also moving my signals to the same location as you. I have a detachable windshield also (haven't used it yet).
Anyway, I spoke to a wrench who told me to pull the bottom screw from the tins and find a thread-matched stainless bolt (hardware store) about 3/4-1" longer than the stock bolt...cut off the bolt head with a hacksaw...pass a nut over the cut to clear the threads...screw the bolt into the lower tin...add a nut (washers optional but not necessary) to lock it to the tin...screw a second nut on the bolt...screw on the signal and position it...and then back the second nut against the signal to lock it tight.
You can cut the bolt to your prefered length for a close fit, or slightly longer to add the slotted rubber/metal donut fitting for the HD detachable windshield. Haven't done the job yet myself, but it looks pretty simple and from what I'm told is essentially the same thing that the HD kit does. Use stainless bolt and nuts...
It may be too late to tell you this but... A friend and I used Harley part number #68373-02 - Chrome Turn Signal Swivel Assembly Kit. This bracket was made for a VRod. I got mine at Zanotti's for about $15. All you do is add a small piece of stainless all thread and a lock nut (fork side). They're chrome and they look good on the bike. These pictures aren't close up but you can tell how they look.
