Starting hicup when hot
Old Nov 8, 2009 | 09:31 PM
2wheeltom77's Avatar
2wheeltom77
Default Starting hicup when hot
Just wondering if anyone else has this problem. It's getting annoying. When I restart hot, sometimes it hits and dies, sometimes it backfires out the intake. Mods in sig. I'm hoping after the cam and new map it might change.
Old Nov 8, 2009 | 09:50 PM
oct1949's Avatar
oct1949
mine did that a few times till I had the stg1, SERT, and dyno done cant remember it since.
Old Nov 9, 2009 | 02:28 AM
Blk and Chrome's Avatar
Blk and Chrome
sounds like its a little lean, not sure what you have for a tuner but if you can adjust it bump up the idle setting. There is also enrichment for starting, some can't be adjusted. If you have cams and a new map installed I'd put it on a dyno. too JMO
Old Nov 9, 2009 | 12:30 PM
2wheeltom77
No cams yet. Just the stage 1 and PCIII. The map is from FuelMoto. I added a bit more fuel at idle and dropped the timing a couple degrees. I suspect the timing may be part of the issue, but it doesn't do it all the time. Usually it only does it when I stop somewhere and some guy on a metric bike is close by when I start it back up. Go figure.
Old Nov 9, 2009 | 12:52 PM
stupid_rope's Avatar
stupid_rope
SEARCH button, there's a few topics on this.
Also, mine does it occasionally. Just give it a little bit of gas when starting it - works for me every time.
Old Nov 9, 2009 | 06:27 PM
2wheeltom77
OK wonderful. Please advise what wording will bring up these threads.
Old Nov 10, 2009 | 09:25 AM
stupid_rope
jesus dude do you want me to read them aloud to you?
Old Nov 10, 2009 | 09:59 AM
Theo's Avatar
Theo
Try tapping the starter switch to turn the motor over. This will open the exhaust ports and release the compression that has built up. I do this every time when I restart a hot motor and have had no problems since.
petejoe43
The Dyno Room
19
Mar 20, 2017 04:43 AM
billybobber
Apr 24, 2011 09:43 AM
neonhomer
Dec 10, 2009 09:14 PM
GasCan
May 31, 2007 11:01 AM
