Slip on's
Old Nov 14, 2009 | 04:43 PM
beerguz's Avatar
beerguz
Question Slip on's
Just orded V&H slip on's yesterday for my Night Train, and the Dealer said I should use the V&H fuel pack with it. I said no thanks, considering the pipes alone cost 450.00, I didn't think I needed to spend another 400.00 because the bike already has a stage one kit installed. Figured I would install the pipes then ride it and see how it runs first. I guess my question is, the fuelpack really needed?
Old Nov 14, 2009 | 05:25 PM
snook592's Avatar
snook592
I would say no as long as you are only doing the pipes
Old Nov 14, 2009 | 07:50 PM
murlsquirl's Avatar
murlsquirl
You can get them for $200 so I don't know if the dealer gave you that $400 number, but that is crazy. I would wait and see if you are happy with the slip ons. You will probably go with a full system eventually and then you would be better off with something that can be tuned (Power Commander).
Old Nov 14, 2009 | 07:54 PM
oct1949's Avatar
oct1949
What are U calling a stg1 kit.?? did U just do a download when it was installed...
stg1 usually means pipes, A/C, and F/M....
Old Nov 14, 2009 | 08:34 PM
beerguz's Avatar
beerguz
The bike originally came with a 2into1 thunderheader, I switched it back to 2 into2 with s.e. slip ons. Pretty sure it is still tuned to the Thunderheader. And that price I quoted is Canadian money. Should have mentioned that.
Old Nov 14, 2009 | 10:08 PM
Colin1966's Avatar
Colin1966
i have done alot of research into the slip-ons and even the dealer told me that there is NO NEED for fuel management when only doing slip-ons with a max of 1.75" baffle. Maybe the service guy did not know the history of your bike or ??
When I bought my 09 Fatboy, it had a stage 1 download /air & S.E. slip-on the dealer installed the mufflers /air and did the download but i changed to 2" Rush (I like). I did contact the dealer to ask if there would be an issue with the Rush 2" and he said that it would not be.
Colin
Old Nov 14, 2009 | 10:25 PM
Phat09flhx's Avatar
Phat09flhx
I wouldn't run a stage 1 and a set of new mufflers,The bike will run on the lean side that could eventually lead to scorched cylinders from running too lean.I have a friend that dynos Harley's for a living,he'd seen that I had put pipes on my 09 FLHX and said I'd better be looking into a tuner before I add the AC or I risk ruin.His suggestion is the Commander.
Old Nov 14, 2009 | 10:45 PM
Colin1966's Avatar
Colin1966
This is what I have been told also by the dealer if you change the air or pipes then you need to deal with F/M but if only slip-ons its NP 1.75" max.
Another question is if going from upgraded pipes back to stock do you need to do a F/M download??? it may very well be a huge fn $$$$ grab.
after reading countless threads and asking people that know WTF they are talking about with years of experience ( i don't) they say that the stock F/M may be able to compensate for the % of difference, MAYBE, so for the sake of $200 is it worth the risk???
Colin
Old Nov 14, 2009 | 10:53 PM
beerguz's Avatar
beerguz
Thanks for your replies.
Old Nov 15, 2009 | 09:12 AM
Heritage632's Avatar
Heritage632
Yeah, I'm a little confused. You said the bike had a stage 1 kit which is usually exhaust, a/c and a fuel management system. I guess you don't have the f/m which is not a full stage 1 upgrade. If you just have exhaust and a/c, you can usually get away with the stage 1 download but if you do a lot of research, you will see that the bike will most likely run lean (and hot) so a fuel management system is highly recommended. Most get a V&H fuel pack if you know you won't be doing any more upgrades. If more upgrades are in the future, you need a Power Commander, SERT etc. Also, $400 for a V&H fuel pack is way off price. I believe they are around $200 and you can get a PC for around $300.
Steve
