Question About ECM
Old Nov 14, 2009 | 05:54 PM
ItsYBob's Avatar
ItsYBob
Default Question About ECM
Hi All, a friend of mine , his bike won't run right just bearley idles, and throws no codes , he wants to put my computer in his bike to see if it will run, will it hert my computer or would it be ok, for him to try it the bikes are both 06, his is a custom softail and mine is a deluxe.
Thanks for all the help
Bob
Old Nov 14, 2009 | 06:07 PM
Other Sheep's Avatar
Other Sheep
Should be fine but if he fries you ECM will he buy you a new one?
Old Nov 14, 2009 | 08:22 PM
oct1949's Avatar
oct1949
might be a lot cheaper and better if he just gets his checked out...
Old Nov 14, 2009 | 11:16 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Switching out the ECM's will work, but I think oct1949's idea is the better and smarter way to go.
Old Nov 15, 2009 | 09:16 AM
ItsYBob's Avatar
ItsYBob
He had spent 200.00 getting it checked out and they told him it was the fuel pump, he takes it back home and puts fuel pump on and it stills just bearley idles. ck the pressure and it is around 45 ( we think it is suppost to be around 65).
sorry about not saying he had taken it in before
he is on fix income not much money, like most people trying to get by as little as possible.
Thanks all
Old Nov 15, 2009 | 09:21 AM
Faast Ed's Avatar
Faast Ed
I'm wondering if a safer option would be to try the 'suspect' ecm on the good bike.
Old Nov 15, 2009 | 10:07 AM
xraybox's Avatar
xraybox
Originally Posted by faast ed
i'm wondering if a safer option would be to try the 'suspect' ecm on the good bike.
bingo!
Old Nov 15, 2009 | 11:30 AM
ItsYBob's Avatar
ItsYBob
now why didn't I think of that, that is the answer, that way don't have to worry abut mine getting fried.
Thank all
Bob
Old Nov 15, 2009 | 12:27 PM
Faast Ed's Avatar
Faast Ed
You're welcome. Please let us know what you find out.
I am quite curious about that, as likely the others are too.
Old Nov 15, 2009 | 01:14 PM
FLTRI17's Avatar
FLTRI17
Default Fuel Pressure
Since the pressure is low, remove the fuel cap and turn the ignition to on and listen in the tank. If you hear a hissing/pissing sound, the internal fuel line(s) prolly has/have a hole in it/them from rubbing on the inside of the tank. The pissing sound comes from the hole spraying fuel into the open tank. Note: This test must be done with no more than 1/2 tank so the holes are uncovered.
This is a common problem and removing the pump/filter/regulator assy from the tank and cycling the ignition/fuel pump will reveal the hole(s).
Hope this helps,
Bob
PS - Swapping ECMs will not correct fuel pressure.
