Question About ECM
Old Nov 15, 2009 | 01:28 PM
Faast Ed's Avatar
Faast Ed
Originally Posted by ItsYBob
He had spent 200.00 getting it checked out and they told him it was the fuel pump, he takes it back home and puts fuel pump on and it stills just bearley idles. ck the pressure and it is around 45 ( we think it is suppost to be around 65).
sorry about not saying he had taken it in before
he is on fix income not much money, like most people trying to get by as little as possible.
Thanks all
The 45 is good. You have good fuel pressure.
"On the fuel rail there is a pressure regulator that limits the fuel pressure to 39-45 PSI and maintains a constant pressure."
http://www.nightrider.com/biketech/m...efi_basics.htm
The fuel line pin-hole thing is also worth exploring, it does happen often enough.
But if it were me, I'd do the ecm thing first, just to eliminate that from the picture.
If it were bad, (with no warranty), I'd be looking at one of the aftermarket self-tune jobbo's.
Old Nov 15, 2009 | 03:31 PM
middermax's Avatar
middermax
3rd Gear
You can test the output of the ECM to see if it's signal is within spec. Its reference output to the sensors is 5VDC. Check it at the TPS for starters. If it's less start checking the circuit backwards looking for the point of voltage drop. If you own a tester already it's a freebie for your buddy.
Old Nov 15, 2009 | 04:57 PM
tk353's Avatar
tk353
Hi All, a friend of mine , his bike won't run right just bearley idles, and throws no codes , he wants to put my computer in his bike to see if it will run, will it hert my computer or would it be ok, for him to try it the bikes are both 06, his is a custom softail and mine is a deluxe.
Thanks for all the help
Bob
so back to the original insure. it has bad idle. i guess it is ok other than that. maybe vacuum leak or ??????????? but i dont think electrical.
Old Nov 16, 2009 | 12:47 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Just because the bike is only 3 or 4 years old I wouldn't discount the idea that one or both of the injectors might be at least partially clogged up with some kind of gunk or dirt.
The tiny holes in an injector can get clogged up fairly easily from dirt and or bad fuel. It can also happen when the bike is allowed to sit too long (long cold winter?) without some kind of stabilizer being added to the fuel.
Old Nov 16, 2009 | 12:21 PM
FastHoss's Avatar
FastHoss
Did I hear someone mention Seafoam?
Old Nov 16, 2009 | 12:41 PM
Faast Ed's Avatar
Faast Ed
Yeah, I did. (Post #16)
Great stuff!
Old Nov 16, 2009 | 04:50 PM
luvtoride's Avatar
luvtoride
does seafoam act as a stabil?
Old Nov 16, 2009 | 05:39 PM
Faast Ed's Avatar
Faast Ed
Yes. It says so on the can at least.
But it is also great for cleaning carbon and other deposits. Can't hurt to spray it in your spark plug holes before storage. Makes that carbon nice and soft in the spring time. (They have a spray version and a liquid version)
Few oz's in your gas tank every third tankful will keep your injectors clean.
Once per year I fog my motor with it. I spray it into the intake til I just about choke the motor out, then shoot a lil in the spark plug holes.
After a half hour or so I will run the motor and spray a fine mist of water down the throttle body while the motor is running..
The theory behind it is the Seafoam softens the carbon, then the water mist acts like a sandblaster on the softened carbon.
Many do the water mist alone to clean carbon (with success). It has to be a fine mist, like from a windex bottle.
Warning: Have good ventilation when you start your bike, because the Seafaom will smoke up the area. (Bigtime). LOL
Old Nov 16, 2009 | 05:53 PM
FLTRI17's Avatar
FLTRI17
Default Fuel Pressure
The old Magneti Marelli EFI on the baggers from 1996-2001 used 46-8 lbs fuel pressure. http://www.nightrider.com/biketech/m...efi_basics.htm (Magneti Marelli EFI not Delphi)
All Delphi systems use 60-2 lbs.
So-o-o-o, if you only have 47lbs the AFR will be/should be excessively lean.
Again, it sounds like you need to take a look inside your fuel tank and not think replacing the ECM will fix the low fuel pressure as it is controlled by a mechanical regulator.
Plugged fuel filter and hole(s) in the internal pressure lines will be the cause(s).
Not trying to start anything but we see this problem frequently and have yet to fix low fuel pressure with a new/different ECM.
Hope you find the problem without getting too far into the wallet,
Bob
Old Nov 16, 2009 | 09:34 PM
tk353's Avatar
tk353
i put berryman b12 injector cleaner every 20,000 miles. running great at 45000 miles
QStar42
Jun 5, 2017 10:09 PM
Kski
May 5, 2010 09:02 AM
pg
Aug 10, 2008 12:22 PM
Koppster
Dec 22, 2007 07:42 AM
Stumpman
May 13, 2006 09:54 PM
