Backfire
Old Nov 17, 2009 | 07:02 PM
SAG's Avatar
SAG
Default Backfire
Help! 2005 Sporster, carburated (but some of you already knew that) after acceleration it backfires. Just started. Cause????
Old Nov 17, 2009 | 07:14 PM
jimsflh's Avatar
jimsflh
Exhaust tight? Battery Cables tight? Hi Octane Gas? Any other symptoms? Idle speed change, running rough at idle, or ruogher than normal while warming up? Also can you recreate it while not riding? (Rev her up to 5 k, then let off) Did flames shoot outta yuor exhaust with the back fire? Help us out here.
Old Nov 17, 2009 | 07:33 PM
2003Springer's Avatar
2003Springer
Changed exhaust lately? That is when you usually start to notice it!
Old Nov 17, 2009 | 08:51 PM
SAG's Avatar
SAG
everything is tight. it only does it when the weather is cold. i cant make it do it when im just sitting. has to have a load on it.
Old Nov 17, 2009 | 09:52 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Sounds like it may be an intake or exhaust leak as when it is warm out everything expands.
Old Nov 18, 2009 | 10:07 AM
tk353's Avatar
tk353
play with the choke and you can tell if it is lean or rich. you may have a issue with high speed jet. simple to remove and clean the carb out
Zfxdb
Apr 26, 2019 12:21 PM
86stc
Apr 24, 2019 05:42 AM
harlow29
Oct 22, 2012 10:42 PM
pimpygrub
Exhaust System Topics
Feb 28, 2010 07:11 PM
wolfwrack
Sep 3, 2008 10:52 PM
