Ape hanger install advice
Old Nov 30, 2009 | 12:27 PM
asianknight1's Avatar
asianknight1
Default Ape hanger install advice
I'm getting ready to start the installing of apes on my Deuce. Any advice before I start?
Old Nov 30, 2009 | 12:55 PM
ranger56528's Avatar
ranger56528
Take a pic or write down were the wires go in the conectors other then that,Have at it..
Old Dec 6, 2009 | 10:03 AM
Schwartz's Avatar
Schwartz
Helped a buddy do that. Make sure you have enough wiring, brake lines, throttle lines, etc...
Old Dec 6, 2009 | 10:14 AM
jason628's Avatar
jason628
Greetings,
Check the other threads on this...It's not a hard job at all. Just go slow, note the wires, and be careful when working around your tank so you don't scratch anything.
Old Dec 6, 2009 | 10:31 AM
neocontra's Avatar
neocontra
Here's some tips I think might be helpful.
1) For removing the tank, get two clamps, and clamp off each side if teh crossover as close to the nipples as you can. Cut the middle of the crossover and lift the tank. Once you have the tank sitting on a shelf or table, unclamp on side to drain the gas in to a container.
Since you now have a good oppurtunity, I strongly recommend you get a quick disconnect for the fuel crossover line. You can find em on ebay (I have a Herko one that works great).
2) If you are extending the wiring, you can get a spool of 14 gauge wire at Lowes or Home Depot cheap.
3) Some people have a preference of solder vs butt connectors, but I personally find butt connectors perfectly adequate and if you get a good crimper and connectors, it will be just as good and much less time consuming.
4) When taking the pins out of the connectors, use a paper clip and angle it curved down towards the pin side when removing each pin. (I know that's a little hard to explain..sorry if that don't really make sense).
5)When reconnecting the wires back into the connector, I use the other connector as a guide. Red to red, white to white, etc.
6) wd-40 inside the apes when pulling the wires through the bars. Lots of it.
Old Dec 6, 2009 | 07:22 PM
m i k e's Avatar
m i k e
brake fluid,trans fluid,gaskets for trans cover,service manual
cables,thrttle,idle,brake,clutch
camera,notepad
good luck post up b4 during & after
heres my link some good stuff in there (post 37-38 then 58 and up)
https://www.hdforums.com/forum/softa...-the-rock.html
Old Dec 25, 2009 | 12:43 PM
asianknight1
Thanks for all the advice guys. My bike is done. Check it out. I also posted it in the photo gallery.
Old Dec 25, 2009 | 12:47 PM
hotrod351's Avatar
hotrod351
looks great, nice clean job.
Old Dec 25, 2009 | 12:50 PM
I8SMK4U's Avatar
I8SMK4U
Looks awsome, welcome to the Planet of the "APES"
Old Dec 25, 2009 | 12:52 PM
hotrod351's Avatar
hotrod351
oh yeah, welcome to the world of = yeah i cant feel anything in my fingers.
