Installing wheels....FINALLY
Old Dec 10, 2009 | 09:43 AM
WARG's Avatar
WARG
Default Installing wheels....FINALLY
I'm ready to install my DNA Mammoths and pulley and roters. I have a lift, torque wrench, and antisieze. Should I have the tires mounted and then install myself or have a dealer do it all? How difficult is the install?
Old Dec 10, 2009 | 09:46 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Have a shop do the tires and put the wheels on yourself. Very easy.
Old Dec 10, 2009 | 10:00 AM
dkyork's Avatar
dkyork
Nice! My DNA Mammoths are still being built. I can't wait to get them on. Do you have a spacer kit or are the wheel hub widths same as your stock?
regards,
Dale
Old Dec 10, 2009 | 10:15 AM
WARG's Avatar
WARG
I think the stock spacers will work except for the pulley. I have a 1/2 inch pulley spacer and a superspoke pulley.
Old Dec 10, 2009 | 10:59 AM
beaureed445's Avatar
beaureed445
I'll believe it when I see it.....ok, just kidding. Good luck. I'd do as Goodies said; have the tires mounted by someone, do the wrenching yourself.
Old Dec 10, 2009 | 01:21 PM
dkyork's Avatar
dkyork
Nice, I'm going to fit mine, measure, and then order the appropriate spacers. I'm going from a 6" hub to a 5.5" in the rear, so I know it'll be different on mine.
regards,
Dale
Old Dec 10, 2009 | 01:54 PM
09_NightRider's Avatar
09_NightRider
What kind of question is that ?
You bought the tools needed to do the job,
then ask if you should pay someone else to do it...
you know you want to get to know your bike a little better.
now go get dirty, and like it man
chris
Old Dec 10, 2009 | 03:09 PM
WARG's Avatar
WARG
I assume I need to use red locktite on the pulley and rotor bolts right? Any other helpful tips? Indy shop is going to charge $34 total to mount and balance. The Dealer wanted $85.
Old Dec 10, 2009 | 03:51 PM
hspring03's Avatar
hspring03
Have the Indy mount and balance and then do the install yourself.
You'll want red on the pulley and rotor...Criss cross pattern...check the torque specs in the manual....
Don't try to muscle the tire in the air while trying to get the axle, caliper, spacers etc...raise and lower the bike on the jack so the wheel is close.
You'll need some fresh brake fluid, you'll need to loosen the MC so that you can open up the calipers to slide back over the rotor.
Good time to double check the brake pads...
Old Dec 10, 2009 | 08:21 PM
micahpop's Avatar
micahpop
Don't forget to post lots o' pics
