04 deuce fi rough cold idle????
Old Dec 10, 2009 | 08:11 PM
dingo67's Avatar
dingo67
Default 04 deuce fi rough cold idle????
i've been having problems with my wife's 04 deuce and can't figure it out. the motor is an injected 88b with a stage 1 air cleaner, martin brothers wtf pipes no baffles, and v&h fuelpak. all was well then resently it started having a hard time starting and idling when cold. once it warms up it runs fine. at first i thought it was the fuel pump because it started make a strange noise when pressurizing the system. i replaced it and the it sounds normal now, but the cold start and idle is still rough. i know it's not the idle control sensor. i pulled the plug and the idle went all over the place and it still stumbled. it's not a vaccum leak, i sprayed all areas that could have a leak with carb cleaner and the idle was un changed. any ideas or answers would be appreciated.
thanks
dingo
Old Dec 11, 2009 | 05:35 AM
Blk and Chrome's Avatar
Blk and Chrome
Ck the idle air control it may be dirty and sticking. They get carboned up I would try cleaning it or may have to replace it
Old Dec 11, 2009 | 08:22 AM
dingo67's Avatar
dingo67
thanks i'll give that a try. it makes sense. love the fi when it's working. hate it when it's not.
Old Dec 15, 2009 | 07:07 PM
dingo67's Avatar
dingo67
Default fixed
ok all
first off thanks to all that responded. second the iac was the problem. i put the new one in and the bikes idle is perfect. i remapped the fuelpak and the bike hasn't ran this good in while. a friend said that you should remap occasionally then ride the bike for about 40 or 50 miles to clear out any junk the ecm may have put in it's memory. by the way the bike never put out any codes so i guess the self diagnosys is worthless.
thanks again
dingo
Deucedog
General Topics/Tech Tips
Feb 14, 2016 09:51 AM
FXD_noob
Nov 18, 2015 10:07 AM
dingo67
Welcome Area Only
21
Feb 9, 2010 06:44 AM
dingo67
Exhaust System Topics
Dec 15, 2009 09:20 PM
dingo67
Dec 15, 2009 09:08 PM
