Handle bar install
Old Dec 11, 2009 | 11:05 PM
casadelray's Avatar
casadelray
Default Handle bar install
I just bought a new set a Klock werks beach cruisers and learned today install may not be as easy as I thought. My initial thought was the wiring harness would easily slip out of the old bars, not so. Looks like I need to de-pin the connectors, slip out of the old bars and install in the new set, then re-pin. More of a PITA than I expected. Is there an easy alternative I'm missing?
Old Dec 11, 2009 | 11:17 PM
WARG's Avatar
WARG
You can cut and splice the wires, but IMO it's just as big of a hassle, if not more, depending on your soldering skills. Pulling the pins is not that bad once you figure it out. Just get a tiny flat head screw driver and file down the end to a point in order to pick the plug to loosen the pins. I think the service manual may show how, but also check out some "how to" videos on YouTube.
Old Dec 11, 2009 | 11:26 PM
DyNaBoB's Avatar
DyNaBoB
pm me and i will send ya my phone number..........its pretty easy just hard to tell ya on here..........im a computer dummy.....lol....jus takes to long for me to type everything
Old Dec 12, 2009 | 11:21 AM
74_ironhead's Avatar
74_ironhead
Just take your time and do it right.
When I did it on my bike I drew a "map" of the wire colors to make sure everything went back in the right pin hole.
To take pins out, just like they said, use a small flathead screwdriver. Personally I would not cut and solder!
Old Dec 12, 2009 | 11:47 AM
neocontra's Avatar
neocontra
Use a paper clip to get the pins out of the housing. When putting the pins back in, you can use the other connector as a guide.
Old Dec 12, 2009 | 12:28 PM
Cheesecake's Avatar
Cheesecake
"de-pinning" is not that hard....I use a bobby pin... just make sure you jot down where everything goes... I'll also take a picture...just to be on the safe side!
CC
Old Dec 12, 2009 | 01:18 PM
jed1069's Avatar
jed1069
Did you get the Mentele bars. Thats what I have on my 09 Fatty. Check out this site for some help on the wiring.
http://wild1inc.com/techtipswiring.html
It was nowhere near as bad as I thought it would be.
NCmtnsrider
Milwaukee Eight (M8)
Apr 16, 2019 11:32 PM
Romans116
Oct 12, 2016 12:25 AM
DynaGuy77
Mar 9, 2012 10:54 PM
WVNightster
Jul 24, 2011 08:52 AM
jshull
Nov 5, 2009 04:27 PM
